stuny Posted December 29, 2014 Share #1  Posted December 29, 2014 Advertisement (gone after registration) On my second day of shooting with my new V-Lux (another generous gift from Barbara) I had an interesting problem: I took several shots which were well exposed and then suddenly they were all underexposed. I overcame that by using exposure compensation (quite a lot of it), but prior to that it was not an issue. I would guess this was the result of hitting various buttons - or at least I hope it was. Of course the printed manual was no help since it is greatly abridged. The downloaded, much larger manual didn't help either, but then I may have missed it  Ideas? Link to post Share on other sites More sharing options...
Advertisement Posted December 29, 2014 Posted December 29, 2014 Hi stuny, Take a look here V-Lux (114) problem. I'm sure you'll find what you were looking for!
pop Posted December 29, 2014 Share #2 Â Posted December 29, 2014 Stuart, may I suggest to show one of the underexposed ones here, with all the meta data intact? They might contain clues to the unexpected settings. Link to post Share on other sites More sharing options...
stuny Posted December 29, 2014 Author Share #3  Posted December 29, 2014 Philipp -  Excellent idea. Here are a before and after example:  Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members!  Link to post Share on other sites Simply register for free here – We are always happy to welcome new members!  ' data-webShareUrl='https://www.l-camera-forum.com/topic/239159-v-lux-114-problem/?do=findComment&comment=2737334'>More sharing options...
ShawnK Posted December 29, 2014 Share #4 Â Posted December 29, 2014 I had couple of slightly under exposed, so I changed the metering mode and was back to normal. Scroll thru' your metering mode settings, that might do the trick. I hope. Link to post Share on other sites More sharing options...
stuny Posted December 29, 2014 Author Share #5 Â Posted December 29, 2014 Shawn - Â Thank you for the idea, but when I tried it nothing unexpected happened. It must be something else. Link to post Share on other sites More sharing options...
waloszek Posted December 29, 2014 Share #6 Â Posted December 29, 2014 Hi stuny, Â I found the following values in the EXIF data (using GraphicConverter): Â Not underexposed: Shutter speed: 1/100 s Aperture: 4.0 ISO: 1250 Â Underexposed: Shutter speed: 1/80 s Aperture: 1.0 ISO: 160 Â (Both have exposure compensation -1) Â So you should check your ISO values. Moreover, an aperture value of 1.0 looks strange to me. Maybe, something went wrong with the camera. As a last resort, you might want to reset it to the factory settings. Â Best regards, Gerd Link to post Share on other sites More sharing options...
ho_co Posted December 29, 2014 Share #7 Â Posted December 29, 2014 Advertisement (gone after registration) Stuart-- I don't have the V-Lux(114) but I have noticed that the Pana-Leicas seem to take literally the set Minimum Shutter Speed, even when that leads to underexposure. Â Might that be the cause of the problem? Â Just guessing, of course. Link to post Share on other sites More sharing options...
stuny Posted December 29, 2014 Author Share #8 Â Posted December 29, 2014 Gerd - Thank you. the -1 was the setting when I started up the camera. since this happened I've increased exposure quite a bit. Â Howard - If it wasn't for the fact that the underexposure suddenly happened I'd think your idea might be related. Link to post Share on other sites More sharing options...
pop Posted December 29, 2014 Share #9  Posted December 29, 2014 I have run both pictures through the EXIF viewer and have made a synopsis from the results. The most striking difference is the F-Stop (1:1 vs 1:4). There is the gain control which may be caused by the differences in the ISO settings, and there are some other settings which may or may not be correct.  underexposed.pdf  As it's quite unlikely that the V-Lux is equipped with a Noctilux, I'd think the failure might be related to the implausible F-Stop. Link to post Share on other sites More sharing options...
Northwest Wanderer Posted December 29, 2014 Share #10 Â Posted December 29, 2014 Stuart, Â If you are experimenting and just learning the various settings you may want to go to the SETUP selection and toggle down to RESET. That will return the settings to the original settings as delivered. Take a picture and see if it looks better. Â Also, you could pull up an image that is not exposed correctly then press DISP until the image data appears. Â Whenever I run into a similar situation I take an additional image in AUTO and compare the data. Link to post Share on other sites More sharing options...
stuny Posted December 31, 2014 Author Share #11 Â Posted December 31, 2014 Thank you, all. Bill's suggestion to reset to factory settings did it. Based on Philipp's last comment I did look at the lens engraving to confirm that it is not a super zoom Noctilux. It isn't. Link to post Share on other sites More sharing options...
wlaidlaw Posted January 12, 2015 Share #12  Posted January 12, 2015 Not a V-Lux but I took my wife's C112 to Taiwan as my pocket camera. I got quite a few wildly underexposed images pretty much at random. I don't know if there is something that confuses the exposure module in these Panaleicas. I switched for a while to taking that camera's version of RAW to get photos, which would have more footroom to make recovery of the underexposed images easier but Capture One does not recognise the particular version of DNG (RWL) which the C112 uses, forcing me to use Lightroom (which I dislike), so went back to JPEG. I found that using aperture priority rather than programme mode seemed to give more consistent exposure and that spot was again more consistent than multi metering.  Wilson  PS Should have added that in the latest version of Capture One (Version 8.1 Pro), Phase One have now added support for .RWL files. Link to post Share on other sites More sharing options...
