Leica User Forum
Go Back   Leica User Forum > International User Forum > Leica Collectors & Historica
090909 Promo
Leica Collectors & Historica This forum is about collecting Leica cameras and lenses. Historica and photographica - whatever the Leica collector wants!
Register now
Old 29.09.2008, 22:36   #21 (permalink)
Benutzer
Erik van Straten's Avatar
Default AW: Re: 1970 summilux 35/1.4-any good?
Another shot with the M2 and the Summilux 35 pre-asph.
Erik.
Erik van Straten is offline   Reply With Quote
Old 30.09.2008, 04:37   #22 (permalink)
Erfahrener Benutzer
maddoc2003jp's Avatar
Quote:
Originally Posted by gravastar View Post
This is to add to my previous post since the "edit time" has expired.
If you use the lens on the M8 and want to mount a UV/IR filter you will find there is no filter thread on the lens. However you can get a series 7 filter from B+W which will mount in the 12504 clip on hood. The hood unscrews into two sections to take the filter. As an alternative to the Series 7 filter I've found if you take a 49mm filter (Leica or B+W) and mount it in the hood with the filter thread facing away from the lens you can screw the two parts of the hood together to hold the filter.
Bob.
Does this work with "normal" thick screw-in filters ? I have two E49 filters from Leica (yellow and red) in E49 for use with my Super-Angulon-M and would like to use them with the hood of my 35mm Summilux and also searching for a not to expensive IR filter ...
__________________
flickr
LFI.
maddoc2003jp is offline   Reply With Quote
Old 30.09.2008, 05:33   #23 (permalink)
Benutzer
Default Re: 1970 summilux 35/1.4-any good?
I have one from 1974, and it's one of my favorite lenses.. nice soft glow wide open, and one of the sharpest i have stopped down.
These are some random shots from the lens and an M8
shot into the sun
wide open
jimcollum is offline   Reply With Quote
Old 30.09.2008, 10:44   #24 (permalink)
Erfahrener Benutzer
stunsworth's Avatar
Default Re: AW: Re: 1970 summilux 35/1.4-any good?
Quote:
Yes, I use a B+W 49mm 486 filter with my Summilux/M8. I'd expect a problem with the 'slim' B+W filters as the outside diameter on those is larger than with a standard filter of the same size.
__________________
Steve
Website - www.steveunsworth.co.uk
stunsworth is offline   Reply With Quote
Old 01.10.2008, 13:57   #25 (permalink)
Erfahrener Benutzer
gravastar's Avatar
Quote:
Both the standard Leica and B+W filters will fit in the hood if reversed. The Leica filters are a solid fit whereas the B+W ones will rattle after the hood has been screwed together. You can fix this if needed with a small piece of packing material.
Bob.
gravastar is offline   Reply With Quote
Old 01.10.2008, 14:17   #26 (permalink)
Erfahrener Benutzer
stunsworth's Avatar
...the B+W ones will rattle after the hood has been screwed together.
The one in mine doesn't, but I have the filter facing the normal way rather than reversed. I wonder if that makes a difference?
__________________
Steve
Old 01.10.2008, 16:54   #27 (permalink)
Erfahrener Benutzer
gravastar's Avatar
With the B+W filter thread facing the lens the two halves of my hood will screw together by less than a quater of a turn.
Bob.
Old 01.10.2008, 18:51   #28 (permalink)
Erfahrener Benutzer
stunsworth's Avatar
Bob, I can't remember how far my lens hood turns, and I won't get a chance to find out until Friday. It's certainly a tight fit - probably due to the milling on the filter and the aluminium of the lens hood.
__________________
Steve
Old 02.10.2008, 03:00   #29 (permalink)
Erfahrener Benutzer
Default AW: Re: AW: Re: 1970 summilux 35/1.4-any good?
Thank you ! I have tested it last night with one of my silver chrome Leica E49 filters and reversed it fits very well. Now I will look for an IR 76 filter in this size.
Cheers,
Gabor
__________________
flickr
LFI.
Old 04.10.2008, 12:41   #30 (permalink)
Erfahrener Benutzer
stunsworth's Avatar
Hi Bob, I've now had a look at my Summilux. With the filter facing the correct way there's about 80% of a full turn before the two halves of my hood lock. The fit feels very solid so I'll stick with that. You are of course correct in that if the filter is facing towards the 'wrong' way the two halves of the hood screw together completely, but there is a rattle.
__________________
Steve
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
