Leicameter MR
roguewave
I just purchased a Metrawatt / Leicameter MR as an additional aide to getting up to sped with the M3. Along with my trusty Gossen Digisix, I hope to get my eyes back into shape to forcast EV better. Any insight/ help about the use,care & feeding would be much appreciated. I have drawn on your wisdom & good graces in the past without fail and stand before you anxious to learn. Thanks again for all the input and recommendations past & hopefully the near future.
I used one for many years on my M3, and it was very easy to use, and accurate as long as it was working! It eventually was beyond repair when a botched previous repair (by a company in East Anglia whose name I cant remember) meant the switch inside broke. You will need to do something about the battery which is no longer available, I used the Wein cell alternative.
Gerry
Hi Ben,
i have a black one and a chrome one. I find them both reliable when used with my M2. It's said that you get an indication of the metering area if you bring up the 90mm lens frame lines.
As Gerry said the main issue is battery power. I have a little adapter sold by a business in the UK that allows you to use currently available batteries. MR-9 Adapter. Replacement for PX625, PX13 or MR9 discontinued Mercury cells..
I have the black version (MR-4) also and use it hand held with my IIIc and IIIg,
i'v also installed the Wein Battery and use the battery check before any shoot.
Find it very accurate outdoors in good daylight conditions but a little bit of a guessing game when it comes to indoor with available light.
Still a beautiful little meter .
Noel
I do use the Varta V 625 U (1,5 V) for the Leicameter MR-4 on my M4.
The meter gives good results. The MR metering is somewhat shorter, but that gives no problems. My Leica RE gives on 'integral' the same results as my Leica meter, and the RE have an excellent meter system....:)
Leicameter MR-4
Do you need its original instructions ? I remember a site in which you can find good reprints of old manuals... but haven't saved the link, sorry...:o
Hi Ben,
Leica Meter MR instruction manual, user manual, free PFD camera manuals Here is the original MR manual. The MR4 differs only slightly.
Guest tummydoc
The MR-9 adaptor adds about 1mm of thickness compared to the PX-625 battery. That's rarely an issue with threaded battery compartments, and even fits OK in the CL, but the MR meter's battery compartment cover is a thin, pivoting piece prone to breakage. The added thickness of the MR-9 bulges the compartment cover outward and puts a lot of strain on the pivot. It is a simple task for someone who knows how to recalibrate the MR for 1,5v batteries. The silver-oxide version retains its accuracy over time whilst the alkaline version tends to lose voltage (and hence, accuracy) as it is used-up.
The Varta V 625 U (1,5 V) for the Leicameter MR-4 will not give any problem to insert!
Keith, you have my highest admiration. We call someone like yourself, ready willing & able to assist a True Boyscout. Hard to get through life without them. Thanks for the links, very interesting reading.
Gerry, sorry for your loss.
Luigi, Keith's got you covered.
Noel, Thanks for the info on the Wein Battery & check off system.
JoopThe Varta is available widely in NYC, thanks for the head's up.
Richard, I 'll call leica NJ to see how many months they'd need to relcalibrate and release. A good option for the summertime.
Vinay, very enlightning. I'll take this to heart.
To all thanks for the assist and getting me up and running. I posted my 1st image with the M3 and am happy to say, I loved the whole process all over again.
Guest tummydoc
It is often the case that due to age and/or corrosion, some older CdS meters designed to function with 1,3v will have "self-adjusted" to where a 1,5v will give passable results, at least through part of the metering range. True re-calibration requires adjustment of both potentiometers (low and high range), otherwise the metering isn't linear (i.e. it is accurate at one end of the brightness range but increasingly inaccurate toward the other end.)
That's correct; personally I do use the MR to get an impression of the light; I do not need a very precisely metering; the MR is more made for a general metering and fast photographing!
Most photographers needs too much time with metering....
The M6 metering has made the M Leica very slow in use...
God, I feel better now... Up to that point I was coming close to agreeing with you! I was going to have to have a lie down in a darkened room to recover - but there, right at at the end, you did not let us down - a nice unfounded sweeping Joop-ism presented as an incontrovertible "truth".
Plus ca change...:D
Regards,
Bill
Joop,
You should get a job with politicians in the UK. They love people who can say everything that no one can disagree with while no one can understand what they mean.You have an art in doing that. We in England have a word that describes that but its rude so I won't say it here. I would love to see some of your pictures - do you have a link?
Best wishes
Bollocks.
I think that may have been the word that Keith was thinking of <grin>.
Of course, the greatest problem with talking bollocks is that they are muffled by your trousers...;)
Regards,
Bill
Joop,
Best wishes
"They love people who can say everything that no one can disagree with while no one can understand what they mean'
...but you do very good understand what I mean....!
You even want to see some of my pictures:D
Plus ca change...:D
Regards,
Bill
'God, I feel better now...'
Hopely better than with your M7...:D
