Stealth3kpl Posted August 30, 2010 Share #1 Posted August 30, 2010 (edited) Advertisement (gone after registration) Take a look at this image. Does it look ok to you (apart from being over sharpened perhaps)? I've looked at it so much this week I can't tell anymore. V700, recommended Vuescan settings. Should I be expecting better? What Vuescan settings do you use? Pete (pulling his hair out). Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited August 30, 2010 by Stealth3kpl Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/129952-slide-scanning-where-am-i-going-wrong/?do=findComment&comment=1422637'>More sharing options...
Advertisement Posted August 30, 2010 Posted August 30, 2010 Hi Stealth3kpl, Take a look here Slide Scanning. Where am I going wrong?. I'm sure you'll find what you were looking for!
andybarton Posted August 30, 2010 Share #2 Posted August 30, 2010 Looks OK apart from the blocked out shadows in the, erm, shadow area. There is some detail there, that you should be able to recover in PS. Great Gable, isn't it? Quote Link to post Share on other sites More sharing options...
adan Posted August 30, 2010 Share #3 Posted August 30, 2010 (edited) Without the original for comparison, it's hard to tell what "wrong" or "better" are. Can you describe what you think is missing? I'd say it is possible to get a lot more detail out of that swath of shadow in the middle (if that's what you want) - and that there is a magenta cast (visible in the cloud highlights and the edges of the cloud shadows). And a lack of saturation, perhaps due to the magenta contamination of the greens. As to the shadows - you probably need to work with the curves when scanning - raising the left-hand side. PS can help, but the more separation you can achieve in the original scan, the better. Edited August 30, 2010 by adan Quote Link to post Share on other sites More sharing options...
}{B Posted August 30, 2010 Share #4 Posted August 30, 2010 If that were one of my scans I would say it was too contrasty and with a blue colour cast showing on the far hills. As for being what you could expect this may be governed more by the scanner you are using than your skill in adjusting the settings in VueScan. There is a whole thread devoted to this problem with the V700 and Vue Scan have you seen it? http://www.l-camera-forum.com/leica-forum/film-forum/136222-v700-vuescan-colour-management.html Sorry I can't be of more help but I don't use Vue Scan. 1 Quote Link to post Share on other sites More sharing options...
andybarton Posted August 30, 2010 Share #5 Posted August 30, 2010 If you are using Vuescan to scan slides, make sure you have set the input to "Image", NOT "Slide" Quote Link to post Share on other sites More sharing options...
Stealth3kpl Posted August 30, 2010 Author Share #6 Posted August 30, 2010 (edited) Without the original for comparison, it's hard to tell what "wrong" or "better" are. Can you describe what you think is missing? I'd say it is possible to get a lot more detail out of that swath of shadow in the middle (if that's what you want) - and that there is a magenta cast (visible in the cloud highlights and the edges of the cloud shadows). And a lack of saturation, perhaps due to the magenta contamination of the greens. As to the shadows - you probably need to work with the curves when scanning - raising the left-hand side. PS can help, but the more separation you can achieve in the original scan, the better. I suppose I feel that it is too contrasty but I'm having difficulty reducing contrast without it appearing dull and bland. I wasn't really wanting to bring out what's in the shaddow particularly - I suppose some will come out when contrast is reduced. It was a bright sunny day but somehow the image doesn't sparkle like I imagined it would. It almost looks like a drawing somehow. I've tried clicking on various greys but this is about the best I could get it. Pete Edited August 30, 2010 by Stealth3kpl Quote Link to post Share on other sites More sharing options...
Stealth3kpl Posted August 30, 2010 Author Share #7 Posted August 30, 2010 (edited) Advertisement (gone after registration) If you are using Vuescan to scan slides, make sure you have set the input to "Image", NOT "Slide" What is the difference between the two settings? I was scanning on Slide. Pete Edited August 30, 2010 by Stealth3kpl Quote Link to post Share on other sites More sharing options...
andybarton Posted August 30, 2010 Share #8 Posted August 30, 2010 "Image" just takes a scan of what's in the scanner. "Slide" tries to correct for a brand and type of film - Vuescan's biggest failing, IMHO, is a lack of up-to-date film types in its database. What type of film was this? Since I was given this tip, I have found scanning slides to be much easier. Quote Link to post Share on other sites More sharing options...
adan Posted August 30, 2010 Share #9 Posted August 30, 2010 (edited) It is inherent in translating slides to "opaque media" (computer screens, paper) that they lose some of their contrast and become somewhat bland. On a projection screen or lightbox, the eye compensates for the extreme brightness range in that it can see into the shadows without losing a sense of the overall "brilliance." Practically speaking, here's a rough rework of your image. Key techniques were: - increasing contrast (making the tone curve steeper) in only the 3/4s tones (the light areas of the mountains) using PS curves. Pinning the bottom half of the tones to avoid darkening the shadows, and pinning the last 5% of highlights to avoid bleaching the clouds. This is probably the key technique, since it restored that color slide "snap" to the pale tones without causing any further darkening of the deep shadows. Get to know and love your "curves" in both scanning and post-processing - they are the most powerful tool for pulling the most out of any image. - selecting the deep shadow and using "Shadows/highlights" and a raised curve sequentially to bring out the detail. - using curves to increase the green and decrease the blue. - Desaturating blues, cyans and magentas (magentas all the way to zero in this landscape shot). With a slight overall increase in saturation. Again, that is what can be done after the fact. And from a precompressed web jpeg. Working from the original, the results would be cleaner and more controllable. Edit- to add an image of the PS curve adjustment used to add brilliance: Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited August 30, 2010 by adan 1 Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/129952-slide-scanning-where-am-i-going-wrong/?do=findComment&comment=1422847'>More sharing options...
Stealth3kpl Posted August 30, 2010 Author Share #10 Posted August 30, 2010 (edited) "Image" just takes a scan of what's in the scanner. "Slide" tries to correct for a brand and type of film - Vuescan's biggest failing, IMHO, is a lack of up-to-date film types in its database. What type of film was this? Since I was given this tip, I have found scanning slides to be much easier. It's velvia but it's a few years old (a friend gave me about 50 films of velvia, sensia and provia) and I think I've under exposed the film in general. I haven't projected them to see how they appear. I suspect I'm on to a loser from the start. Strangely, my Vuescan set on Slide only has presets for Kodak. Do you have any Fuji profiles on yours? Pete Edited August 30, 2010 by Stealth3kpl Quote Link to post Share on other sites More sharing options...
Stealth3kpl Posted August 30, 2010 Author Share #11 Posted August 30, 2010 Thanks ADAN. My scans are coming out so dark from the scanner that I've started to suspect my exposures are all wrong. I think this is one of the better exposed images. I've played a few times with the curves and white/black points and brightness in Vuescan but really don't seem to get anywhere. I think I'll dig some of my old slides out and see if that makes any difference. I didn't seem to have this problem in the past. Pete Quote Link to post Share on other sites More sharing options...
jerryharwood Posted August 30, 2010 Share #12 Posted August 30, 2010 Hi, I've upgraded my Vuescan software to version 2- since then, and having really studied the beast, I find that there is a great improvement. I too am using an epson scanner, but I found the standard epson software virtually useless. I did have Silverfast, which is vastly different, but it is much much more expensive, although somewhat easier to use. Now, I use vuescan almost all the time; it does pay to study it though, as it is quite comprehensive, but patience does help ! I use fuji Velvia 50 and 100 almost exclusively, which I find does help a little, as you become used to the parameters of both speeds of the film. Hope this helps a little. 1 Quote Link to post Share on other sites More sharing options...
Stealth3kpl Posted August 30, 2010 Author Share #13 Posted August 30, 2010 Thanks for your encouragement, Jerry. I've PMed you. Pete Quote Link to post Share on other sites More sharing options...
Stealth3kpl Posted August 30, 2010 Author Share #14 Posted August 30, 2010 and that there is a magenta cast (visible in the cloud highlights and the edges of the cloud shadows). ADAN, is this something you've judged by eye or do you use some sort of eyedropper in photoshop to check the colour balance at various points. What's the trick to colour balance? Pete Quote Link to post Share on other sites More sharing options...
adan Posted August 30, 2010 Share #15 Posted August 30, 2010 Both. I sometimes crank the saturation WAY up temporarily since that will visually reveal subtle color casts (in the case of your image, the pink in the clouds). I also use the eyedropper, backed up with 35 years experience analysizing and color-balancing probably 50,000 images (digitally and in wet color darkrooms). Sometimes I use PhotoShop's "Variations" adjustment to judge casts (usually not for making the actual corrections) - it is analogous to the color viewing filters we used in wet darkrooms for judging color balance: Amazon.com: 3 Density Color Print Viewing Kit: Camera & Photo 1 Quote Link to post Share on other sites More sharing options...
andybarton Posted August 31, 2010 Share #16 Posted August 31, 2010 If it's Velvia you're using, then you are starting at the "hard" end of the scale. It's pretty unforgiving of exposure and has very little latitude, as you have found from your shadows here. It might be an idea to practice with a slide that doesn't show such extremes. 1 Quote Link to post Share on other sites More sharing options...
tobey bilek Posted August 31, 2010 Share #17 Posted August 31, 2010 It looks perfect. The blue color in the far hills belongs there. Now there is the issue of the big shadow. IF there is detail there in the negative, I would make a second scan with correct exposure for the shadow only, layer them in photoshop, use the arrow keys and temporary difference mode to get perfect allignment, then mask the dark shadow on the top layer so the lower correctly exposed shadow shows thru. I do this all the time and it works well. Without photoshop, I have no idea how to accomplish it. 1 Quote Link to post Share on other sites More sharing options...
Julian Thompson Posted August 31, 2010 Share #18 Posted August 31, 2010 Pete ColorPos and use gamma C 2.5 on that image. Try that. Quote Link to post Share on other sites More sharing options...
Stealth3kpl Posted August 31, 2010 Author Share #19 Posted August 31, 2010 Thanks, I will. I've been scanning tonight and have got much better files out than before (TIFFS rather than TIFF RAW) so I'll have a play with software later. I think I'm getting closer to what I'm trying to achieve. It may not be to everyone's taste but it's close to what we saw. Pete Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/129952-slide-scanning-where-am-i-going-wrong/?do=findComment&comment=1424095'>More sharing options...
Stealth3kpl Posted August 31, 2010 Author Share #20 Posted August 31, 2010 Looking from Esk Hawse to Keswick. Pete Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/129952-slide-scanning-where-am-i-going-wrong/?do=findComment&comment=1424194'>More sharing options...
