x
I don't seem to find any clear info on the possibility/feasibility of using ND filters with the 2 new lenses. Would someone be able to comment?
Thanks
There was a thread about this recently. The best idea seemed to be to slip a gelatin ND filter behind the UV/IR filter.
Also, Tiffen are making combined IR blocking/ND filters (they seem to call them Hot Mirror IRND) though it's not clear whether they are yet available in "Series" mounts.
Thanks
B+W | Series 8 #103 Neutral Density (ND) 0.9 Glass | 65073081
i think this is it. special order and cant use it with IR filter since there is only room for one filter with the current set up (unless you buy the filter adapter)
Just to clarify the previous comments:
The IRND filters are currently only produced for motion picture cameras - so it would be a very large piece of glass on the end of a typical m mount sized lens!
Due to the M8 having a relatively high minimum ISO of 160 I have ordered a B+W 46mm ND.9 filter for my summilux so I can always shoot wide open outside. There is no reason why it shouldn't be able to stack on top of an existing UV/IR filter on longer lenses but on 21 and 24 it may cause additional vignetting. It is a shame there is no slim version of this and the UV/IR filters for wide angle lenses as I can safely stack slim mount filters on my wide canon lenses without any issues.
The thing is that the new Summiluxes use a Series VIII filter retained by the lens hood. Regardless of possible vignetting there's only room in the hood for one glass filter.
I have contacted John Milich about a custom lens hood with standard filter thread. He has not handled the lens yet, but I hope I have planted a seed.
I think that holder on a lens like the 24 will block at least 50% of the viewfinder. And as we are talking narrow-DOF here, an accessory viewfinder won't work.
yeah...might be available by the time I've saved enough for a 21 lux :cool:
Thanks David. That's very nice to know. I believe that would mean without any hood?
Correct. These adapters don't allow use with the hood. The only way to use filters with the hood is to use series 7 or 8 filters.
David
  • 9 years later...
