PasMichiel Posted April 8, 2009 Share #1 Posted April 8, 2009 Advertisement (gone after registration) I have a question: What are the changes that have to be made on the R8 to have de DMR fit and work? How can I see that that is already done? I have a Third version of the R8 as I could see in the list: Leica FAQ - R8 versions and serial numbers So probably I don't have a problem with the electronics. Link to post Share on other sites More sharing options...
Advertisement Posted April 8, 2009 Posted April 8, 2009 Hi PasMichiel, Take a look here R8 and DMR modification. I'm sure you'll find what you were looking for!
andybarton Posted April 8, 2009 Share #2 Posted April 8, 2009 Later R8s should work fine with the DMR, and even some older ones don't have any problems. However, the firmware in the camera needs tweaking on older models, and Leica will change the gold contacts from the flat head ones to rounded head ones, to ensure better contact with the DMR unit. Leica updates the firmware whenever an R8 is returned to Solms for any kind of service, but the contacts change needs to be requested specifically. As far as I know, Leica do not charge you when changing the contacts. My R8 still has the flat contacts, and it worked fine with the DMR when I owned one, so you may or may not be lucky. Link to post Share on other sites More sharing options...
PasMichiel Posted April 8, 2009 Author Share #3 Posted April 8, 2009 Thanks for the fast response. Doe you mean round contacts in behind the back or the ones in the bottom? Link to post Share on other sites More sharing options...
andybarton Posted April 8, 2009 Share #4 Posted April 8, 2009 All of them, I think. Definitely the ones on the bottom, though. As I said, mine worked fine without the modification, so I have no first hand experience of which ones. Link to post Share on other sites More sharing options...
PasMichiel Posted April 9, 2009 Author Share #5 Posted April 9, 2009 You probably can tell me what kind of ground glass people use. I think the spitscreen is okay,but some change that when they go digital. Why? And some people change the view-finder with magnifying glass. But why? Do you become blind when you go digital? Link to post Share on other sites More sharing options...
jaapv Posted April 9, 2009 Share #6 Posted April 9, 2009 It is more the lens you use. The universal is fine for most applications, but long/slow lenses and macro work much better with a full matte screen. The full matte witrh grid is excellent for wideangle work and the microprism one - well, rather for nothing:o. The clear with cross is when the body is fitted to a microscope. Link to post Share on other sites More sharing options...
Overgaard Posted April 9, 2009 Share #7 Posted April 9, 2009 Advertisement (gone after registration) Here's the screens if one (as I) can't remember which is which. I too use the Universal screen again after having used a Microprism screen from Brightscreen. I guess, without thinking about it normally, what I do is I use the center of the Universal screen to get towards focus but then often use the outer matte area to see when it's in focus. It's almost like intuition to use a matte area, but I think it works the best. http://en.leica-camera.com/photography/r_system/accessories/accessories_for_the_camera/viewfinder_accessories/3820.html Link to post Share on other sites More sharing options...
PasMichiel Posted April 10, 2009 Author Share #8 Posted April 10, 2009 Thanks for the reply. I know the different screens. But there is nothing about the preferred one for digital. I do like the universal. I used it with the R4, R5 en now on the R8. With the universal I can focus in three methods so you can check it one way or the other. I start with the split part. I try to get a straight part (with a portrait for example: nose or glasses). Then I look if the grid part is fading away and for the focus depth I look at the rest. But I can't think of anything changing that going digital. Is it? Link to post Share on other sites More sharing options...
andybarton Posted April 10, 2009 Share #9 Posted April 10, 2009 The preferred screen for the DMR is the one that comes with the DMR - that has the crop frame on the glass, so that you can see what the sensor is going to record. It also has the trad split screen and microprisms. Focussing is no different when using the DMR as when you are not. The lens doesn't know it's on a camera with a DMR, neither does the focussing screen. You use the camera exactly as normal, but just have to remember the crop - hence the guidelines on the screen. Doug Herr uses a plain ground glass screen, though, IIRC. Link to post Share on other sites More sharing options...
PasMichiel Posted April 10, 2009 Author Share #10 Posted April 10, 2009 Aha. Now I understand. Not everything witch you see will be on the picture. It's not full frame. Of course. What is exactly the factor? x1,5? So, a 50mm will be 75mm? Or something? So the crop screen is a kind of universal screen with grid as Overgaard showed in the picture at the bottom right. Link to post Share on other sites More sharing options...
andybarton Posted April 10, 2009 Share #11 Posted April 10, 2009 The crop factor is ~1.3, so a 50mm becomes a 65mm equivalent. Not quite - it looks like this one http://www.bhphotovideo.com/c/product/388758-REG/Leica_14395_Uniform_Ground_Glass_Focusing.html The experience is very similar to that of using an M - you can see beyond the "frameline", in this case, beyond the "crop line". Link to post Share on other sites More sharing options...
PasMichiel Posted April 10, 2009 Author Share #12 Posted April 10, 2009 Yes I saw after I posted it. It's less what I sometimes do now. I use an adapter to an EOS . Yeah sorry... I couldn't find a DMR the right price. Most of the times I make analogue pictures which I develop in my own darkroom. But when I am lazy... I take a Canon (with a Leica lens) I do hate it however. I don't have the spit screen for example. And it's small. So this is a better place to look (so I should have the 14 392): http://www.summilux.net/r_system/racc_f.htm R8/R9 14 343 R8/R9 + Digital-Modul-R 14 392 Link to post Share on other sites More sharing options...
