cosmonaut Posted March 14, 2008 Share #1 Â Posted March 14, 2008 Advertisement (gone after registration) I outfitted my new M6 with a Nokton 40mm which the M6 has no framelines for. I am going through a learning curve of sorts hitting the mark since I only have 35mm and 50mm framelines close to the 40mm. I seem to be to far away or to close. But if I just ignore the framelines all together and just fly by the seat of my pants I do better. I do have a 35mm Color Skopar on my IIIa I could use I guess but was wondering did any of you have a learning curve when going to the Leica's. Does it get easier with time and what is the best suited MM lens for the job. I am thinking of a 50mm once I can afford a Leica lens. Any thoughts?Bythe way I love the speed of the Nokton and am also thrilled with the results I have been getting so far, quality wise. the Color Skopar seems a bit more contrasty. Link to post Share on other sites More sharing options...
Advertisement Posted March 14, 2008 Posted March 14, 2008 Hi cosmonaut, Take a look here Framelines @ .72. I'm sure you'll find what you were looking for!
photophile Posted March 14, 2008 Share #2 Â Posted March 14, 2008 I use a 21 on my m6 very routinely. have not been able to find my ext viewer fo over a year. have just learned in my mind's eye roughly what is in and what is out. you will be best served by shooting the 40 exclusively for a while.. you'll get frame lines in your mind.. good luck. CH Link to post Share on other sites More sharing options...
veraikon Posted March 14, 2008 Share #3 Â Posted March 14, 2008 Perhaps this may helpyou (even if it is en francais ) summilux.net :: Voir le sujet - Modification Nokton 40mm 1,4 Link to post Share on other sites More sharing options...
octo Posted March 14, 2008 Share #4 Â Posted March 14, 2008 Actually, unless you focus down to the minimum distance, the image registered by the negative will become larger than the frames as you focus towards infinity: you'll record outside the frame. So, I'd advise you to use the 35 frame for distances from 3/4 meters onward. Closer, use the outside of the 50 frames as a starting point to make test exposures and fix it into your mind. Link to post Share on other sites More sharing options...
bill Posted March 14, 2008 Share #5 Â Posted March 14, 2008 Philippe is absolutely right, of course. In strict terms, the FOV is as shown below. Â [ATTACH]78307[/ATTACH] Â I have the 40 and find it to be a good "street" lens in that I can frame using the 50 lines and know that I have have a good chance of capturing what's going on in the "enhanced" field of view. Â Regards, Â Bill Link to post Share on other sites More sharing options...
cosmonaut Posted March 14, 2008 Author Share #6 Â Posted March 14, 2008 Thanks for all of the valuable help. I guess there is nothing like practice as well. The pictures and chart helps me. Thanks Link to post Share on other sites More sharing options...
