andym911 Posted August 14, 2010 Share #1 Posted August 14, 2010 Advertisement (gone after registration) Okay, I also hate 'what should I buy threads' but this is my first so be gentle please. Currently own lots of film cameras and mainly use M6, CL, F3 and occasionally the LTM when I'm feeling nostalgic. Am currently lusting after a new M (meterless) and have read up on the M2 and M3. I shoot 99% of the time with 35mm and 50mm , very occasionally 28mm. the question is which model to buy....are there really any differences apart from frame lines? thoughts and opinions are welcomed best andy Link to post Share on other sites More sharing options...
Advertisement Posted August 14, 2010 Posted August 14, 2010 Hi andym911, Take a look here M2 or M3 . I'm sure you'll find what you were looking for!
JanCderidder Posted August 14, 2010 Share #2 Posted August 14, 2010 try to get an M4, might be a bit more expensive but have some "more stabile" technicalities. I have been using a 1968 one for 20 years now, went in for a ... is it CLA once just after I had got it and functions perfectly, up until today, and I still, despite digital, shoot a roll a month on average. I think the m3 have this double trigger thing, which is a pain to use. Right now if you want to get the real B/W leica thing I'd go for a series 0 barnack, the replicas which where introduced som 12 years ago, I have one, it's not only a gem to look at but produces really nice results with tri-x ..... Link to post Share on other sites More sharing options...
andym911 Posted August 14, 2010 Author Share #3 Posted August 14, 2010 jan thanks for the reply....0 Barnack is not what I am after, am looking for an M. I shoot mainly B&W and use TriX along with Neopan and Delta. The M4 just does not inspire me although I am sure it's a fine camera. I have the M6 and M7 and CL but am looking for a fine mechanical, smooth small M to be used with separate Light Meter. thanks again andy Link to post Share on other sites More sharing options...
lct Posted August 14, 2010 Share #4 Posted August 14, 2010 ...Am currently lusting after a new M (meterless) and have read up on the M2 and M3.I shoot 99% of the time with 35mm and 50mm , very occasionally 28mm... Depends on your favorite lens: 35 or 50. If it's 50, the M3 is for you. If it's 35, the M2 is a must. Link to post Share on other sites More sharing options...
andym911 Posted August 14, 2010 Author Share #5 Posted August 14, 2010 LCT because of the need for the goggles? andy Link to post Share on other sites More sharing options...
stunsworth Posted August 14, 2010 Share #6 Posted August 14, 2010 My first M was an M2. I've also owned an M3. If I were buying another un-metered M body it would be an M2. I know the M3 is where the M started, but I loved the M2 for the 35mm framelines. Link to post Share on other sites More sharing options...
andym911 Posted August 14, 2010 Author Share #7 Posted August 14, 2010 Advertisement (gone after registration) build quality same or similar?...I do use 35mm half the time BTW andy Link to post Share on other sites More sharing options...
stunsworth Posted August 14, 2010 Share #8 Posted August 14, 2010 build quality same or similar? You could use either to hammer in a nail. People may say that the M3 was more expensive to manufacture, that the M2 was a cut down version of the M3, but in practice both are amazingly well engineered, and the brass gearing in both gives as silky a smooth film advance as it's possible to imagine - I migrated to an M6, but I'd be the first to admit that the feel of an M2/3 is something special. Link to post Share on other sites More sharing options...
dkCambridgeshire Posted August 14, 2010 Share #9 Posted August 14, 2010 The M2 rangefinder design is totally different to that of the M3 ... M2/3/4 Rangefinder Restoration dunk Link to post Share on other sites More sharing options...
NZDavid Posted August 15, 2010 Share #10 Posted August 15, 2010 The M2 is logical, but if you really like the big frame finder of the M3 with the 50, then an accessory 35 viewfinder (Voigtländer is good) would be a solution for the times when you mount the 35 -- far less bulky than a goggled 35 (though I have a spare 2.8/35 Summaron). Link to post Share on other sites More sharing options...
lars_bergquist Posted August 15, 2010 Share #11 Posted August 15, 2010 Do check out the M3, if that's what you are lusting after: • Very early M3 cameras (1954--early 1955, before no.785891) do not have the frame preview lever. • Until no 854001 (1957) the camera used the old speed sequence -- with 1/10, 1/25, 1/50, 1/100, 1/200 -- and not the modern geometrical progression (1/8, 1/55, 1/30, 1/60, 1/125, 1/250). • The M3 had a double-stroke film wind until 1958 (no.915251). In other words, the M3 was a piece of work in progress. The basis of modern M cameras is the M2. That of course lends a certain old world charm to the M3, if that is what you are after. The old man from the Age of the M3 Link to post Share on other sites More sharing options...
lct Posted August 15, 2010 Share #12 Posted August 15, 2010 ...I do use 35mm half the time BTW... Then the M2 is for you. Or another .72x M. Or a 0.58x M if you shoot most of your another half with 28 or wider lenses. Link to post Share on other sites More sharing options...
Xmas Posted August 15, 2010 Share #13 Posted August 15, 2010 If you want fast handling shooter for 35mm and 5cm then it is the M2. If it is dark and you are using a f/0.95, you may need a magnifier as well. The M3 if you only use 5cm. Both may need the quick load kit, and rewind assist, if you want slick handling like a M6 but the very early M3 should not use the rewind assist. They are both smooooooooooooth, but need careful inspection, and may need a service, if the lubs is stiff/gummy. Noel Link to post Share on other sites More sharing options...
andym911 Posted August 15, 2010 Author Share #14 Posted August 15, 2010 thanks to all....will start searching for a good condition M2, and as always plan on a CLA. Many thanks Andy Link to post Share on other sites More sharing options...
earleygallery Posted August 15, 2010 Share #15 Posted August 15, 2010 I prefer the M2 but then I mostly use the 35 lens with it. Also, I found the rounded corners of the M3 framelines very irritating. Link to post Share on other sites More sharing options...
Jaybob Posted August 16, 2010 Share #16 Posted August 16, 2010 I use both M3 and M2. I use M2 for the 35 and M3 for the 50 and 90. But if I were you, and meterless is what you want, I'd take the battery out and stick with the M6. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/128527-m2-or-m3/?do=findComment&comment=1407803'>More sharing options...
sadiepaige01 Posted August 19, 2010 Share #17 Posted August 19, 2010 The frame counter wheel on the M2 doesn't get inadvertently knocked out of place, in my experience (and it only turns in one direction anyway), so I wouldn't worry about that. What does trouble the compulsive in me, though, is the fact the counter doesn't quite line up squarely with the pointer. Others cameras may not have this issue, or you may simply not care! I trust you are aware of the different versions of the cameras: M3 single or double stroke; with or without preview lever; with or without depth of field markings. M2 is simpler -- with button or lever rewind; with or without selftimer. Link to post Share on other sites More sharing options...
earleygallery Posted August 19, 2010 Share #18 Posted August 19, 2010 The frame counter wheel on the M2 doesn't get inadvertently knocked out of place, in my experience (and it only turns in one direction anyway), so I wouldn't worry about that. What does trouble the compulsive in me, though, is the fact the counter doesn't quite line up squarely with the pointer. Others cameras may not have this issue, or you may simply not care! When I received my M2 the pointer lined up exactly. It then went off for a CLA and came back perfect, apart from the counter now being about a mm off! I would suggest something similar has happened to yours, there's probably tiny little cogs that it fits over and its just a cog out. No doubt an easy DIY fix but I'm not bothered by it though, I still know how many frames I've got left. Link to post Share on other sites More sharing options...
wizard Posted August 19, 2010 Share #19 Posted August 19, 2010 I shoot 99% of the time with 35mm and 50mm, ... You yourself give the answer, as the M3 does not have framelines for 35mm . The M3 is best suited for 50mm and up. There is nothing quite like it in that range. Andy Link to post Share on other sites More sharing options...
Pintpot Posted August 19, 2010 Share #20 Posted August 19, 2010 I got a near mint (It had been adapted 'cos it's got the m6 viewfinder frames) M2only 5/6 weeks ago and am very much enjoying using film agan. I find it easier to focus and frame than my M8. Link to post Share on other sites More sharing options...
