UVa for 18 mm Super Elmarit
TDR
I have been happily shooting with my 18mm Elmarit on my M8. I have been using the Leica UV/IR filter made for that lens (part #13422). I just ordered an M9. Is there a Leica UVa filter (without the IR) designed for that lens? I can't seem to find one.
Tim
It seems that you will have to use the filter adapter with a 72mm lens. On the other hand, the combination of the screw-in hood and a front cap will protect your lens mechanically fully as well as a filter, and there
will be no photographic benefit from using one, either. Leica lenses have been opaque to hard UV since the 1960's, when improved lens cement and coatings were introduced.
The old man from the Age of the Yellow Filter
Thanks for your replies to my question. I checked with B&H, which confirms that there is no UV-only equivalent of the UVa/IR filter for the 18. But the rep said that continuing to use that UVa/IR filter on the M9 would not affect my photos. The advice I've seen in other posts here has been that you should not use the IR filters with the new M9, which has the built-in IR filter that most cameras have. So, will it make any difference in my pictures if I keep using the Leica IR filters on my lenses on the M9?
Tim
You wouldn't want to keep the uv/ir filter on the SE18 while shooting full frame, it vignettes _a lot_. As for other lenses, normals to teles shouldn't be an issue. Wide angles will give you varying degrees of colour vignetting depending on how wide the lens is.
Carl
  • 1 year later...
Carl
Just found this thread, so I know I'm late. Are you saying that the Leica filter #13422 which is made for the SEM 18 vignettes?
It is just beyond me, with the M9 having been out for 2-3 years now, that Leica has not come with UVa filter for the SEM 18 for use with the M9!
