Yippy_Kiyey Posted September 24, 2009 Share #1 Posted September 24, 2009 Advertisement (gone after registration) What is the best way to remove a scratch on the LCD screen. I have a D-Lux 4 and I dscovered that the screen has a couple of scratches. Link to post Share on other sites More sharing options...
Advertisement Posted September 24, 2009 Posted September 24, 2009 Hi Yippy_Kiyey, Take a look here LCD screen scratch remover . I'm sure you'll find what you were looking for!
Sherwood Nash Posted September 24, 2009 Share #2 Posted September 24, 2009 As I have it lying around I use 'applesauce' Applesauce Polish Restores the Original Finish to Your iPod Sherwood Link to post Share on other sites More sharing options...
graeme_clarke Posted September 24, 2009 Share #3 Posted September 24, 2009 Try toothpaste, which is a very fine polishing mixture (not the gel type though) on a very soft clean cotton or microfibre cloth - rub gently in a small area and keep changing the cloth and paste frequently. Polish the used paste away gently with another clean cloth. Car polishes such as T cut, and household polishes such a Jif or Brasso are not as fine as toothpaste. Hope this helps. Graeme Link to post Share on other sites More sharing options...
tobey bilek Posted September 24, 2009 Share #4 Posted September 24, 2009 Auto stores sell Scratch Doctor. Fine abrasives like toothpaste will take a month of rubbing if it more than a slight surface scratch. If deep, you will need something more agressive to start and then work back to a finer grit. White, not red, rubbing compound is as agressive as I would get. An autobody supply store can sell you different grades. If you know a metalurgist, he can get you polishing compounds. I use 1 micron and finish with .3. That is point 3, not 3 I have done lots of plastic like watch crystals with it. Idea, A watch repair person will have these supplies. Link to post Share on other sites More sharing options...
Yippy_Kiyey Posted September 24, 2009 Author Share #5 Posted September 24, 2009 Thank you so much for your suggestions. I feel good now that I know that there is way the remove LCD scratches. Link to post Share on other sites More sharing options...
gravastar Posted September 25, 2009 Share #6 Posted September 25, 2009 Not to pour oil on troubled waters, but you do need to be careful. I tried to polish out scratches on a Canon SLR screen with unsatisfactory results. Many screens have a thin toughened or hardened surface layer. If you penetrate this when polishing the underlying soft plastic does not take a polish and remains somewhat matte in appearance. The only solution after I'd polished out the scratch was to use a screen protector with an adhesive backing. The adhesive filled in the micro scratches and restored the screen to it's clear state. In fact you may like to try that first and see if the scratch is rendered less visible. Bob. Link to post Share on other sites More sharing options...
jaapv Posted September 25, 2009 Share #7 Posted September 25, 2009 Advertisement (gone after registration) Most LCD screens are coated. You will polish away the coating, just making it worse. The best thing to do is to stick a screen protector over it. That will hide the scratches. Link to post Share on other sites More sharing options...
