Dedalus Posted September 18, 2009 Share #1 Posted September 18, 2009 Advertisement (gone after registration) Hi there, I'd like to buy an M6 with either a 35 or a 50. I currently have a R9 with the starter 35-70 and a cron 50 which I'm using constantly but would like to try out the M system. I'm currently based in Paris but travel often to london and frankfurt. I know a bit the places in London but would like to know if you think Frnakfurt is a good place to buy used Leica equipment and if you could recommend a place or two. In terms of prices what do you think I should budget for a body and prime in tip top shape? I'm not necessarily looking for TTL, a M6 classic would do. Thanks for your help, Manuel Link to post Share on other sites More sharing options...
Advertisement Posted September 18, 2009 Posted September 18, 2009 Hi Dedalus, Take a look here M6 plus 35 or 50. I'm sure you'll find what you were looking for!
alun Posted September 18, 2009 Share #2 Posted September 18, 2009 To judge by UK dealer pricers at present, you could probably expect to get a decent used M6 and Summicron 35/2 for the equivalent of about GBP 1400.00-1600.00 -- perhaps a little more, perhaps a little less, depending on condition and age of both the body and lens (and assuming you buy pre-asph. lenses). You could reduce this by around GBP 200.00, I guess, by buying an older generation lens (whether 35mm or 50mm). Unfortunately I can't say whether Frankfurt is a good place to shop but others will undoubtedly know. Good luck. Link to post Share on other sites More sharing options...
Dedalus Posted September 18, 2009 Author Share #3 Posted September 18, 2009 Thanks Alun! I hope to hear from others. Best, Manuel Link to post Share on other sites More sharing options...
