Leica X1 or Panasonic GF1 + M glass
Pinocchio Wood
  • Replies 53
  • Created
  • Last Reply
Panasonic are to produce an M adapter. So should I buy that body and use my M glass. Which would produce better images?
I'm sure the GF1 and M glass would take great pix - just remember that your 50mm becomes a 100mm (etc). X2 multiplication due to sensor size...
There is already an M adapter out for Micro Four Thirds, and I think there has been for a while, just as there has been an M adapter for Four Thirds.
Question is, is there an M adapter for the Sony/Minolta DSLR mount?
Which would produce "better" images...
Sigh.
Whichever tool you feel most comfortable with, I suspect.
Can you take pix that are any good with what you have now? If not, a new camera won't help you much. :eek:
1. To get the same field of view on the Panasonic that the X-1 has, you'll need to use an 18mm M-mount lens. Take your pick -- the 18mm Zeiss f/4 or the Leica 18mm f/3.8. Do the math. You can buy the 18mm Leica lens for only $2,900 US and the Zeiss for only $1,100 US.
2. First reports from people who used M-mount lenses on the G-1 showed poor results from lenses shorter than 35mm. The expectations were that the results would be great -- the reality proved different.
People keep looking for this magic bullet solution that gives them a cheap camera upon which to use good lenses. If you have M-mount lenses, your best bet is to look for a used M8, M8.2, or M8u. You'll take a little hit with the 1.33 "crop" factor. The M8 bodies are still perfectly good -- if you can't make decent pictures with one, you should probably stay with permanently mounted P&S cameras that cost less than $1,000.
Nope. But there are solutions to have your Leica R lenses converted to Sony/Minolta mount (google Leitax adapter). This is a reversible solution, and more solid IMO than an intermediate ring/adapter. I have been using a converted Summicron-R 50/2 with a Minolta 9xi, and it is perfectly working.
Leica R lenses on the recently announced full frame 24something MP Sony Alpha 850 at a hair under US$2000 sounds like a really appealing move.
I have a third party M-adapter for my Panasonic G1, and results vary largely with the Leica lens used. IQ with the wider angle lenses is not as good as expected. There's corner softness and light fall off with the 28/2,and with the 21/2.8. In any case, the kit lens seems to outperform these M lenses, thanks to in-camera processing that improves corner quality, corrects for chromatic aberrations and compensates vognetting.
There's no subtitute though for the larger aperture Leica lenses. A 35/1.4, 50/1.4 or a 90/2 offer far shallower DOF and more pleasant bokeh than any other micro4/3 available lens, retaining the excellent resolution they are famous for.
The more interesting questions are how good will the 20/1.7 Panny and 45/2.8 Leica u4/3 macro lenses be? As was said above, trying to go wide with adapted lenses usually isn't pretty on u4/3. I had a CV 40/1.4 on E-P1 and that was fine, but I don't think you can get good performance much wider than that...and remember that is 80mm equivalent.
  • 1 month later...
I plumped for a GF1 with the adapter and viewfinder and am very happy with my choice.
The cost of the GF1 with adapter and Electronic viewfinder is in the same price bracket as the X1 although it is obviously much more versatile.
I have noticed that the performance on the wider M lenses does indeed suffer (CV 12mm Ultra Wide for example) but it is still producing really nice images which only improve once you get past 35mm.
The GF1 also has a really nice workflow for me too. I very quickly settled on MF with the electronic viewfinder and now able to press the MF zoom button, focus then depress the shutter release and finally fire the shutter release again to capture my final image. I am stunned by the final quality, especially when you pop some Leica glass on there as well.
In closing. The GF1 is a stunning camera. Certainly the best of the compact four thirds breed at the moment but therein lies the difference. The X1 sensor is much larger. The X1 is a completely different format of camera that just happens to share some of the same external appearances.
Once I handle the X1 and once I've read some proper reviews, I dare say I will be buying the X1 as well. That will basically mean I will be able to use my M lenses and the new X1 on two cameras that still come in well below the M9 and as such, I don't see these cameras as competition, rather for me as companions.
Paul
For my flickr slideshow of images regarding and taken on the GF1, click here.
Could you tell us please which third party adaptor you have? I have just bought a G1, and the Panasonic adaptor is very expensive in the UK, about 4 x the price of some of the others.
Thanks, Gerry
Thanks, Gerry
I have the 'official' Panasonic one. Yes its incredibly dear but I'm very wary of the quality of some of the third party ones that are available.
I also like the fact that I can either detach the adaptor and lens from the camera body or by using the 'opposite' notch, I can just detach the lens, leaving the adaptor in place for the next M-mount lens to be fitted with minimum fuss.
A quick shot using the Novoflex adapter and Leica/Minolta Rokkor 40mm f2 on the GF1.
While waiting for M9 to be available, I have been using my M glasses with the Pana G1. Corners are indeed soft, but you get the nice Leica 3D signature!
Here are a few examples with the Leica 18 mm SE and 24mm 2.8.
And here one with the 35mm Summicron.
Full image, crop center of the image, and the soft corner.
Thank you for sharing these images.
Wasn't there a 25mm Summilux for Four Thirds? Couldn't this be adapted to the GF1 as well?
However, looking at the images of the 1,4/25, this combination should be almost as large as the M8 with the 50mm Summilux...
Stefan
  • 2 weeks later...
