Storing a camera -- with desiccant?
jrethorst
Another thread on the forum, How to Store Equipment, addresses more general issues, but doesn't especially discuss humidity. I live in Seattle, which is humid, and thought I should pack the camera with desiccant bags. An apparently knowledgeable manager of a local camera store said that would not be a good idea, since the desiccant would draw so much moisture out of the air it would dry out the camera's seals, which would then crack as a result. I would not have thought that modern "rubber" (i.e. petroleum-based chemical) seals contained any water. He said just inside (not garage or basement) would be fine. What do you think?
I'm not expert but I would have thought Seattle is not humid like Singapore is humid. On the other hand, I'm not sure what seals the "apparently knowledgeable manager" is referring to. I must have missed them when I took my M8 apart.
Basically, if the place where you store you camera is comfortable for you, it will be fine for the camera.
My last house I lived it I did not store my canon A1 with desiccant 15 years no trouble moved into my next rat trap of a house and in one year I had fungus junk growing on my viewfinder now I alway use desiccant in the metal tin with the window that way I know when to bake it bring back to life. Pelican cases are good to, the desiccant in the tin is made by pelican.
Jan
I live in Vancouver - about 120 miles north from you and - about 1/4 mile form the ocean. If you think Seattle is humid, you have not visited the East Coast, the Great Lakes region or South-East Asia. Now - THAT is humid!
Seriously - in Seattle you should have no problems with humidity; it may rain more than elsewhere but, the air is relatively dry. My cameras are all over the place - cabinets, drawers, bags etc, with no Silica gel desiccant in sight and have been 'stored' like that since I moved to Vancouver 30 years ago. No fungus, oxidation, or any other humidity related issues.
As to your "apparently knowledgable manager" - I hope you don't rely on him on some really important information..... :rolleyes:
Best,
Jan (another one)
I should have been more specific. You're entirely right that the East Coast and other places seem much more humid; their wet season is summer, and we feel humidity much more when it's hot.
Seattle's and Vancouver's rainy season is winter. Relative humidity is an expression of how much water the air is holding relative to how much it can hold. Warmer air can hold more water, so the absolute humidity can be much greater when it's hot. Relative humidity is a useful measure since cool air such as the Northwest has in winter still has enough water to condense on objects like cameras. Mildew is a fairly common problem in these parts.
Good to know.
Just remember to regularly change the silica gel as Leicanut2 eluded to. As Silica gel is most effective when rejuvenated. There are ways of drying the silica gel (see google)
If you really want to get paranoid, the object one is trying to keep dry, together with the desiccant should be stored in an airtight container. You could track the weight of the package of silica gel, once it has increased more than about 20 to 25% of its dry weight, it's really lost its efficiency.
Extreme paranoiacs will change the silica gel each time the air-tight container has been opened.......
  • 2 weeks later...
Can get very humid here in New York City & many years ago bought a drybox from Totech bassed inToronto but, at their suggestion, set the humidity at 40-45% so as not to dry out the lubricant... Their product is superb and trouble-free.
I suspect that it what the initial writer was alluding to as there ARE NO SEALS on any Leicas with the exception of the S2...:D
