efftee Posted August 29, 2009 Share #1 Posted August 29, 2009 Advertisement (gone after registration) Just picked up a dry cabinet and wondering what's the ideal temperature and humidity for an M8, lenses, etc. Thanks in advance for your comments. Link to post Share on other sites More sharing options...
Advertisement Posted August 29, 2009 Posted August 29, 2009 Hi efftee, Take a look here Ideal Storage Temperature & Humidity . I'm sure you'll find what you were looking for!
cocker Posted August 29, 2009 Share #2 Posted August 29, 2009 Its a camera not a cigar. Keep your Bolivars in the cabinet. Link to post Share on other sites More sharing options...
efftee Posted August 29, 2009 Author Share #3 Posted August 29, 2009 When you live in a country with humidity up in the 90's, you'd wouldn't be so cocky, uh I mean, cocker. Link to post Share on other sites More sharing options...
Nicoleica Posted August 29, 2009 Share #4 Posted August 29, 2009 I would think that somewhere in the 40-60% relative humidity (Non-condensing.) and a temperature in the 15-25 C range should be OK. (Keeping the temperature closer to ambient will help prevent condensation forming when you take the camera and lenses out.) I wouldn't keep your batteries in there though. It's drying out that tends to kill them. Link to post Share on other sites More sharing options...
SJP Posted August 29, 2009 Share #5 Posted August 29, 2009 50 RH and 18-20°C I would expect Link to post Share on other sites More sharing options...
efftee Posted August 30, 2009 Author Share #6 Posted August 30, 2009 I would think that somewhere in the 40-60% relative humidity (Non-condensing.) and a temperature in the 15-25 C range should be OK. (Keeping the temperature closer to ambient will help prevent condensation forming when you take the camera and lenses out.) I wouldn't keep your batteries in there though. It's drying out that tends to kill them. Thanks, SJP and Nicole. Just how bad is it for the battery? It's quite a pain to be fiddling with the battery everytime it goes in the cabinet. Link to post Share on other sites More sharing options...
SJP Posted August 30, 2009 Share #7 Posted August 30, 2009 Advertisement (gone after registration) The battery itself is (or should be) hermetically sealed, so it should be insensitive to changing environment. The constant temperature and RH should prevent condensation/moisture etc. so that is presumably good for the electronics. Why did you get this cabinet - are you in a high humidity part of the world, tropics or the like? In a moderate climate standard living room/office conditions should be good enough & climatisation should not be necessary. Link to post Share on other sites More sharing options...
scaryink Posted August 30, 2009 Share #8 Posted August 30, 2009 I am not aware of many people keeping their other electronic components in a humidor where there is high humidity. It is Leica after all and while not sealed, is intended to survive in environments where humans live and press shutters. Link to post Share on other sites More sharing options...
efftee Posted August 30, 2009 Author Share #9 Posted August 30, 2009 The battery itself is (or should be) hermetically sealed, so it should be insensitive to changing environment. The constant temperature and RH should prevent condensation/moisture etc. so that is presumably good for the electronics. Why did you get this cabinet - are you in a high humidity part of the world, tropics or the like? In a moderate climate standard living room/office conditions should be good enough & climatisation should not be necessary. Yes Stephen, I'm in Singapore, where the humidity is up in the 90's. With the high humidity and quite severe temperature change from night (18ºC; air-conditioner on) to day (30ºC; air-conditioner off), a dry cabinet is quite necessary. I just replaced a simple dry box with a cabinet that has some 'environmental' controls and wondering what the ideal temp and humidity would be. Link to post Share on other sites More sharing options...
brill64 Posted August 30, 2009 Share #10 Posted August 30, 2009 living in hong kong and working around the region the humidity is mostly high in the region of 70-98%. i consider a relatively inexpensive dry cabinet essential gear particularly to prevent the formation of mold or fungus between lens elements, leica or not. after a long, hot day i store lenses overnight with end and front caps off in the dry cabinet at around 50%RH and same goes for the camera especially during typhoon season or if it gets wet. it's common sense here, really but may not seem so from a less temperate perspective Link to post Share on other sites More sharing options...
ns_ng Posted August 30, 2009 Share #11 Posted August 30, 2009 Just picked up a dry cabinet and wondering what's the ideal temperature and humidity for an M8, lenses, etc. Thanks in advance for your comments. Hi, As I lived in a tropical country, I have been keeping my M and R equipment in a dry cabinet for years. The recommended RH is around 40-45% as this will prevent fungus from growing. Do not use a very low RH, <25% as this might dry out the oil and lubricants. N.S. Ng Link to post Share on other sites More sharing options...
chris_tribble Posted August 30, 2009 Share #12 Posted August 30, 2009 I maybe spending some time in Guangzhou next year (investigative stage still) and would be living on a university campus with good, but not brilliant accommodation - if I wanted to get a dry cabinet, anyone with an ideas on whether this would be available in the PRC and how much it's likely to cost? (I lived in Sri Lanka for 4 years and saw what the climate could do to kit. With an M6 the mould could be cleaned off the shutter - I'd not like to mess with an electronic camera to that extent though... Link to post Share on other sites More sharing options...
photolandscape Posted August 30, 2009 Share #13 Posted August 30, 2009 Ideally, 50% RH and 68 degrees F. Link to post Share on other sites More sharing options...
fotoism Posted August 30, 2009 Share #14 Posted August 30, 2009 I maybe spending some time in Guangzhou next year (investigative stage still) and would be living on a university campus with good, but not brilliant accommodation - if I wanted to get a dry cabinet, anyone with an ideas on whether this would be available in the PRC and how much it's likely to cost? (I lived in Sri Lanka for 4 years and saw what the climate could do to kit. With an M6 the mould could be cleaned off the shutter - I'd not like to mess with an electronic camera to that extent though... Chris: Just found this on eBay: item number 260467694001. Looks decent enough. Link to post Share on other sites More sharing options...
efftee Posted August 30, 2009 Author Share #15 Posted August 30, 2009 N.S., thanks for the <25% tip! Chris, dry cabinets are easily found in camera stores in Asia, even the electronic ones, and they are considerably less expensive than what you can find online, including on eBay. Link to post Share on other sites More sharing options...
chris_tribble Posted August 30, 2009 Share #16 Posted August 30, 2009 N.S., thanks for the <25% tip! Chris, dry cabinets are easily found in camera stores in Asia, even the electronic ones, and they are considerably less expensive than what you can find online, including on eBay. Thanks for this - advice noted! Link to post Share on other sites More sharing options...
Arif Posted August 31, 2009 Share #17 Posted August 31, 2009 First time I stayed in Japan, I witnessed my wallpaper slowing coming off due to the high humidity. A dry cabinet is considered essential here and most auctions/ads on resale especially Leica specifically mention storage in a dry cabinet to allay any mold/fungus fears. I keep mine in the 50-60% and temp around 70. Best regards, Arif Link to post Share on other sites More sharing options...
Bo_Lorentzen Posted August 31, 2009 Share #18 Posted August 31, 2009 Never thought about this.. living in LA maybe I should get a humidifier from a cigar store. Link to post Share on other sites More sharing options...
manolo Posted August 31, 2009 Share #19 Posted August 31, 2009 I use the humidity absorption recipients and just change the white granules every few months. Anyone els use this? Link to post Share on other sites More sharing options...
A. Cheng Posted August 31, 2009 Share #20 Posted August 31, 2009 I use the humidity absorption recipients and just change the white granules every few months. Anyone els use this? I use humidity absorption recipients (in a linen packet) as well by putting them in the tight-seal plastic box which houses a few lenses and the m8. I also put a thermometer with RH gauge insdie the box to monitor the climate info. I didn't realize <25% maybe harmful but now I learn and will find a way to 'control' it. Link to post Share on other sites More sharing options...
