elansprint72 Posted August 21, 2009 Share #1 Posted August 21, 2009 Advertisement (gone after registration) Not the usual failed sensor thing, working one minute, will not switch on the next. I've tried several charged batteries- nothing. Any suggestions? Thinks...... is it possible that the sensor can fail completely, without showing the rainbow streaks? Link to post Share on other sites More sharing options...
Advertisement Posted August 21, 2009 Posted August 21, 2009 Hi elansprint72, Take a look here Digilux 2 dead- totally.. I'm sure you'll find what you were looking for!
hamey Posted August 21, 2009 Share #2 Posted August 21, 2009 Sorry to hear that pete. But it's a Digicam, it's life has probably past it. Hopefully you can fix it. I once made a comment about expensive Digicams with fixed lenses. Pity you cannot use the lens, as I beleive it's an excellent peice of glass. Ken. Link to post Share on other sites More sharing options...
jrethorst Posted August 21, 2009 Share #3 Posted August 21, 2009 Sorry to hear that pete.But it's a Digicam, it's life has probably past it. Hopefully you can fix it. This doesn't happen very often apparently, judging from the posts here. These cameras were made from 2004 to when: 2006? Outside of the sensor, which is fine once replaced, the D2 seems very reliable. Anyone have a big repair horror story to share? Any reason why, with a minor repair every three or five years, we can't continue enjoying that beautiful lens forever? Link to post Share on other sites More sharing options...
daveleo Posted August 22, 2009 Share #4 Posted August 22, 2009 hi there sorry about your D2. i have had mine since early 2004. when the sensor failed (2007 or 8 ?), i got a totally black screen (no stripes ..... no slowly degrading images ..... sudden black screen). i had the sensor replaced and it's been fine since then. Link to post Share on other sites More sharing options...
kknox55@gmail.com Posted August 22, 2009 Share #5 Posted August 22, 2009 Mine is at Leica USA now, it had a failed circut board. It worked then just gave me memory card error and then that was it. They are putting a new sensor in under warranty but the circut board repair is $375.00 + shipping. Hope yours is something simple. Good luck Kevin Link to post Share on other sites More sharing options...
stuny Posted August 22, 2009 Share #6 Posted August 22, 2009 Pete - My first D2 needed the sensor replaced, and before that needed the rubber coating reapplied and the lens controls looked at (felt gritty). All that, plus a firmware upgrade were free. In February in Rwanda the SD card door broke, but using a band-aide (plaster) I was able to keep it working. The repair estimate was more than a used D2 replacement. Leica offered me a "demo" unit for $500, which I bought, and It's working fine. I'd send it to Leica for an estimate. Link to post Share on other sites More sharing options...
elansprint72 Posted August 22, 2009 Author Share #7 Posted August 22, 2009 Advertisement (gone after registration) hi theresorry about your D2. i have had mine since early 2004. when the sensor failed (2007 or 8 ?), i got a totally black screen (no stripes ..... no slowly degrading images ..... sudden black screen). i had the sensor replaced and it's been fine since then. Your misfortune give me hope that it might be the sensor, although I would have thought I should still get the little switch-on click. I'll send it in this week. Thanks for your contributions, guys, anyone else able to report faults other than the sensor? Link to post Share on other sites More sharing options...
brucek Posted August 22, 2009 Share #8 Posted August 22, 2009 anyone else able to report faults other than the sensor? I had a memory card get stuck in mine and Leica had to replace the circuit board. Still worth the price of the repair to me. Bruce Link to post Share on other sites More sharing options...
kknox55@gmail.com Posted August 22, 2009 Share #9 Posted August 22, 2009 Good luck I should have mine back in 2 weeks. What are we going to do, you can't just toss it out. It will work like new when it comes back. Kevin Link to post Share on other sites More sharing options...
rijve044 Posted August 23, 2009 Share #10 Posted August 23, 2009 Your misfortune give me hope that it might be the sensor, although I would have thought I should still get the little switch-on click. I'll send it in this week. Thanks for your contributions, guys, anyone else able to report faults other than the sensor? For stationary circumstances you can use the battery charger, plug in the 8.4 V cable (supplied with the camera) and connect it with the camera behind the left door. (USB and AV side) It's only a hint. greetings and succes. Dre Link to post Share on other sites More sharing options...
elansprint72 Posted August 23, 2009 Author Share #11 Posted August 23, 2009 For stationary circumstances you can use the battery charger, plug in the 8.4 V cable(supplied with the camera) and connect it with the camera behind the left door. (USB and AV side) It's only a hint. greetings and succes. Dre Does not seem to be part of the UK-supplied kit, unfortunately, great idea though. Link to post Share on other sites More sharing options...
wda Posted August 23, 2009 Share #12 Posted August 23, 2009 Not the usual failed sensor thing, working one minute, will not switch on the next. I've tried several charged batteries- nothing. Any suggestions? Thinks...... is it possible that the sensor can fail completely, without showing the rainbow streaks? Pete, I am very sorry to hear your news. Has it already had a sensor change? If not, send it to MK. Link to post Share on other sites More sharing options...
rijve044 Posted August 23, 2009 Share #13 Posted August 23, 2009 Does not seem to be part of the UK-supplied kit, unfortunately, great idea though. hoi pete In my d2 manual directly after table of contents there is a delivery status. you should have 3 cables (USB/AV/ and DC cable) Even the french manual states it. so either you left them in the box or if you bought it second hand the former owner did not hand it to you (and that happened to me) but you can try at your local electronic shop, the plugs are common in 230V AC to 12V DC adaptors. Diameter of the plugs are 4.7 mm and the inner pin is + on both sides. Anyway take the camera or battery charger with you for correct measure. Costs a couple of € ~I suppose. Succes greetings Dre Link to post Share on other sites More sharing options...
krabat Posted August 24, 2009 Share #14 Posted August 24, 2009 I bought my Digilux 2 in March 2004, and since then it went three times to the customer service. For the first time, I had stumbled and fallen, causing mechanical damage inside (and a nasty scratch in the ring of my UV filter), then, secondly, the chip gave up its mind, and as third, water came into my flat due to flash flood after a sudden heavy rainfall, and my camera was in a traveling bag standing on the floor... The last incidence did cost me 550 Euros... But the camera was worth it! Link to post Share on other sites More sharing options...
ajthornbury Posted August 25, 2009 Share #15 Posted August 25, 2009 It is possible for the the sensor to fail in the way described, in any case with current high second hand values, it would pay to have a repair done, sensor or not. Link to post Share on other sites More sharing options...
elansprint72 Posted August 25, 2009 Author Share #16 Posted August 25, 2009 .........with current high second hand values, it would pay to have a repair done, sensor or not. Which is the fault of all the idiots on this forum who post wonderful images and sing the praises of this obsolete dinosaur. Link to post Share on other sites More sharing options...
Guest stnami Posted August 25, 2009 Share #17 Posted August 25, 2009 Pete it looks like it is back to the trench coat and the trusty old rollei...... Link to post Share on other sites More sharing options...
elansprint72 Posted August 25, 2009 Author Share #18 Posted August 25, 2009 Pete it looks like it is back to the trench coat and the trusty old rollei...... Link to post Share on other sites More sharing options...
John Thawley Posted August 26, 2009 Share #19 Posted August 26, 2009 Which is the fault of all the idiots on this forum who post wonderful images and sing the praises of this obsolete dinosaur. Hey, if you were located on the proper side of the pond, this idiot would lend you one. Link to post Share on other sites More sharing options...
kaethe Posted August 26, 2009 Share #20 Posted August 26, 2009 hmmmm. i have had my digilux 2 since 2004, had the sensor changed last winter, and now the multi-frame doesn't function, only get two images or none. in addition, i was shooting some baskets of purple yarn to check colors, as i usually only shoot b/w and the colors were quite pale, but ok on general still life/landscapes. leica said it may be the ccd, so send it in, and they will take care of it under warranty. off it goes to new jersey tomorrow, we shall see. so hard to give up on this camera. kaethe Link to post Share on other sites More sharing options...
