Shutter actuation?
JLV
Hi all ,
I thought that it was not possible to know how many shots were taken with an M8 (I bought mine second hand) and on the add section of the forum, there is a M8 for sale where the saler indicates "shutter actuation 6 172".
Is there a way to get this information on each M8?
Thanks,
Jean-Luc
You can see that, for instance, on Adobe Bridge. On the EXIF you will see a field "Image Unique ID". This should look like sommething like this 000000000000000000000000000013DD
This figure is in HEX (Hexadecimal) so you have to convert it into DEC (Decimal). You can do that using Windows Calculator on Scientific mode. You select "HEX", you enter the number (not necessary the leading zeros, in this case you enter just 13DD) and you select now "DEC". You will get 5085. That's the number of shutter actuations ;)
Irfanview has a EXIF reading plugin exif.dll that should work I think (I can't install it at work to try it out). IrfanView - Official Homepage - one of the most popular viewers worldwide but Jaap's photome suggestions looks more convenient.
You can use google to convert hex to decimal, example "0x13DD to decimal" gives 5085 see here
