Chris Schoeler Posted July 20, 2009 Share #1 Posted July 20, 2009 Advertisement (gone after registration) Hello, today I work with a Leica M8 and a Hassel with a digital back. For several reasons sometimes I still need my Digilux 2. For special occasions when I need to be faster, even more quiet or simply because I can feel that Digilux 2 will render the best jpegs with no need for raw files. I just found a problem in my Digilux 2, I tried to find this issue in the forum but I couldn't. The camera just do not turn off. Everytime I turn the button to off position, or the camera automaticaly try to turn off all I get is the red dot on the EVF or Lcd. The only way to finish the process is taking the battery off. I was looking for a way to reset the software or something like that, but there is no firmware available to reinstall. It should be simple and I would like to not send the camera for service. Any advice? Thanks. http://www.christianmaldonado.com http://www.schoelereditions.com Link to post Share on other sites More sharing options...
Advertisement Posted July 20, 2009 Posted July 20, 2009 Hi Chris Schoeler, Take a look here Digilux 2 does not turn off. I'm sure you'll find what you were looking for!
John Thawley Posted July 20, 2009 Share #2 Posted July 20, 2009 Hello, today I work with a Leica M8 and a Hassel with a digital back. For several reasons sometimes I still need my Digilux 2. For special occasions when I need to be faster, even more quiet or simply because I can feel that Digilux 2 will render the best jpegs with no need for raw files. I just found a problem in my Digilux 2, I tried to find this issue in the forum but I couldn't. The camera just do not turn off. Everytime I turn the button to off position, or the camera automaticaly try to turn off all I get is the red dot on the EVF or Lcd. The only way to finish the process is taking the battery off. I was looking for a way to reset the software or something like that, but there is no firmware available to reinstall. It should be simple and I would like to not send the camera for service. Any advice? Thanks. http://www.christianmaldonado.com http://www.schoelereditions.com Have you tried leaving the battery out for 24 hours? Because of the time settings and things like that, there is some energy storage in the chip. Leaving it overnight "might" reset the camera. Just a guess. JT Link to post Share on other sites More sharing options...
ajthornbury Posted July 21, 2009 Share #3 Posted July 21, 2009 I agree with John, take out battery for 48 hrs then replace and try.This happened to me once and this worked. Good luck. Link to post Share on other sites More sharing options...
Chris Schoeler Posted July 21, 2009 Author Share #4 Posted July 21, 2009 I agree with John, take out battery for 48 hrs then replace and try.This happened to me once and this worked.Good luck. Ok, I tried for 24hs and didn't fix the problem. Now I will wait for more than 48hs to see what happens. I will let you guys know. Thanks for the suggestions. Link to post Share on other sites More sharing options...
rsolomon Posted July 23, 2009 Share #5 Posted July 23, 2009 ...also make sure the battery is fully charged whn you put it back in. weird things sometimes happen when the camer battery is low. Also i would have the camera in the off postion when replacing the battery - Link to post Share on other sites More sharing options...
Chris Schoeler Posted August 19, 2009 Author Share #6 Posted August 19, 2009 Thank you for all your help, I tried everything. I left battery out for 24hs, 48 hs, then a week. I fully re-charged the battery everytime. Recently I left the camera on until the battery is off. I still have the same problem. Any:(body knows about a software to reboot or reset or even reinstall the firmware? One of these should be the solution. Christian Link to post Share on other sites More sharing options...
