Grip for M8 work or not?
Mark2007
  • Replies 44
  • Created
  • Last Reply
I would not be without grips on either film or digital M's. The M8 is quite a bit bigger as you can see from photos below. However, I find it makes the grip much more secure, particularly one handed, if you use a 3M Bumpon (20 x 20 x 12.5mm) on the back see below also. These cost pennies, so very little lost if you don't like them.
Wilson
Hi Wilson,
Yes, those 3M Bumpon are great on the camera, I did like it much, but it's better to use it in a cold weather.
Mine slips on the side, as the hot sun brought the glue to melt. :o
Cheers.
Hi Wilson,
Cheers.
Philippe,
The Bumpons I sent you were generic ones. I too found the non-3M one I had on my M4 slid off in very hot weather or if it was left in the sun. The genuine 3M ones are much better but unfortunately, much more difficult to find.
Wilson
IMHO the Leica grip is too big, I went with the Thumbs Up which provides several more functions besides providing a solid grip.
I bought the grip over two years ago and haven't had it off since. The fact that it is more rounded gives it a small crevasse you can hook your fingers into when carrying it. I use it with a fairly tight wrist strap and the combo means I can carry it around all day, hanging by my side until needed, without fatigue.
I have small hands, so maybe that's why it's so comfortable for me.
I might consider a Thumbs Up, but haven't had the opportunity to try one yet. I am wearing out the black where my thumb rests, though, so maybe that should tell me something...
Doug
I used the grip for awhile but it made the camera too bulky for me so I covered particular areas of my M8 body with ordinary black anti-slip tape and I haven't used the grip since; it also makes the camera look less attractive to thieves I think.
If you use a 135/2.8 goggled Elmarit I think you need to take the grip off to attach the lens - I don't have one so can anyone confirm or deny please?
Pete.
Yes, the goggles catch on the grip handle and you can't attach/remove the lens without first taking off the grip :(.
Bob.
Sometimes, honest to god...
I picked up the M8 with the grip, to swing it around a little before I replied to this thread, fired a couple of shots and then, on the third one, it froze up. It's been a while since I've had a problem. Changed batteries, and it's working again, but the other battery was nearly fresh. Should I be worried?
About the grip, I think it all depends on your style. When I'm really using it, I tend to dangle the camera from my fingertips, with the shoulder strap wrapped around my wrist. I like the feel of that, because it's very relaxed -- I'm not actually *gripping* it. I think I'd have a hard time using the camera without the grip.
Tried it once but much prefer the Thumbs up. With it, the handle is just perfect that I don't feel I need the grip.
I find the perfect combination to be a grip + Thumbs Up; I have stopped using my Luigi half case.
I liked it at first but then to my eye it spoiled the look of the camera, so I left it off and have never used it since. Now I am just used to holding the camera as is and dont seem to have a problem. Never tried a thumbs up.
One other point when I used it I often inadvertantly placed a finger over the rangefinder window.
Jeff
Jeff, your comment does suggest that your M8 is an object to admire, rather than a functional tool. For my part, I found the finish of the M8 far too slippery for my liking. Since fitting the grip I use it far more confidently, have no problem blocking the viewfinder window and have never needed the support that Thumbs-Up provides.
I certainly add my voice of support for the Leica grip. It has transformed the ergonomics for me.
Be assured that my M8s get plenty of use, but it is true that I dont like the look of the camera with that upright tube bracketed onto it. I knew someone would pick up on that comment. I have small hands perhaps that is why I have no problem holding the camera, basically as suggested in the M8 manual. As I said I did also find that my finger covered the rangefinder patch when using the grip. A different covering on the camera would improve my grip even more but I'm not going to go to the trouble of changing it.
I also bought the Leica 1.25 magnifier but now dont need that either. These were both purchases I made shortly after getting the camera. I just prefer to use the camera as is, nothing wrong with that is there?
Jeff
Jeff
I agree with you on all counts. But if you really want a good grip of the camera put the Camera Leather's GripTac on it.
I'm going to order 3 more today and switch out the one that has leather on it so I can stop using the grip base on that camera. That way both M8's will have the same feel.
I'm very happy using the Luigi 1/2 case with built in grip and a Thumbs Up. I use this with a "sling", the camera is very stable in the hand and easy to grab with this combination
LDH
the grip is a MUST for the use of a M8...
Clearly it isn't as many of us find it appallingly designed, over priced, and don't use one. There again I don't like the Thumbs Up either [though I applaud Tim's efforts]. I think the OP's money would be better spent on changing the camera covering to a Camera Leather one, and modifying the end of the strap for the right hand by making it chunkier [wrapping cord around it if you're posh, string if you are not] - it helps. Yes really!
I'm a string kinda guy.
............ Chris
(Thanks, Mark P)
Does anyone have any idea why the M8 grip is roughly twice the price of the M7 grip? :eek::confused:
Pete.
Yes - the M7 grip is a piece of over priced plastic junk (IMHO). The M8 grip at least does have a decent build and generally you get a reasonable grip.
Personally I prefer the Photo Equip ML & MD Grips or Luigi grip case as an alternative where I'm not bothered about using a tripod plate.
I've never felt the need for grips on my M6, MP or M8 cameras, even with large and heavy lenses.
They always seem like they clutter up the camera and really aren't needed in my opinion.
Noah,
When you get a bit older and have arthritic hands with stiff fingers (my hands were also damaged in a motor racing accident), you might like me, find the grips on both film and digital M's, indispensable.
Wilson
