dritz Posted July 11, 2009 Share #1 Posted July 11, 2009 Advertisement (gone after registration) Shooting my 3rd roll today with the R9. I switched to manual, spot meter mode, and the "lo" display came on regardless of the actual shutter speed or aperture. The center weight and matrix metering work correctly, but the spot meter always displays as insufficient light. I tried with new batteries as well as a fully charged motor drive. Same problem. Advice? Link to post Share on other sites More sharing options...
Advertisement Posted July 11, 2009 Posted July 11, 2009 Hi dritz, Take a look here Help diagnosing R9 spot meter problem. I'm sure you'll find what you were looking for!
Overgaard Posted July 11, 2009 Share #2 Posted July 11, 2009 Sounds like the meter mechanism is kaput. Just had mine replaced at Leica. It started out with only the spot-metering behaving weird, then the other metering methods as well. It was a 500 € experience to get this fixed, as well as the camera checked, adjusted and all in the same process. Link to post Share on other sites More sharing options...
