aesop Posted June 24, 2009 Share #1 Posted June 24, 2009 Advertisement (gone after registration) ...quick darkroom question - has anyone out there ever successfully used a Focomat V35 with a Focotar-2 50mm lens? I just tried to (with and without extension tube 17675) but do not seem to be able to focus the image manually. Does not make sense to me. I would particularly appreciate feedback from folks with actual experience with the above combination. Thanks. Link to post Share on other sites More sharing options...
Advertisement Posted June 24, 2009 Posted June 24, 2009 Hi aesop, Take a look here Focomat V35 with Focotar-2 50mm . I'm sure you'll find what you were looking for!
tobey bilek Posted June 24, 2009 Share #2 Posted June 24, 2009 When new, a 50mm auto focus cam could be ordered to replace the 40 mm. Or the machine culd be ordered with a 50 mm Rodenstock Yasaron lens as a cheaper alturnative to the 40. There is a point with the proper extension where it will focus, but it might be 5/12/18 mm extension and then it will not AF properly anyway. Link to post Share on other sites More sharing options...
aesop Posted June 24, 2009 Author Share #3 Posted June 24, 2009 When new, a 50mm auto focus cam could be ordered to replace the 40 mm. Or the machine culd be ordered with a 50 mm Rodenstock Yasaron lens as a cheaper alturnative to the 40. There is a point with the proper extension where it will focus, but it might be 5/12/18 mm extension and then it will not AF properly anyway. ...thanks, tobey bilek. The Focotar 40mm 2.8 is my regular lens, but I have always wondered what the effect would be if I used my Focotar-2 50mm with the funky V35 lightbox. I glibly assumed the 50mm + 17675 would focus manually on the V35, but hey, you learn something new every day. I have some other extension tubes stashed away somewhere and I hope one of them will provide a solution. Again, thanks for the support. Link to post Share on other sites More sharing options...
palec Posted July 9, 2009 Share #4 Posted July 9, 2009 Hi, I use 8mm extension tube with 50mm lens on Focomat V35. I can manually focus without problems. Link to post Share on other sites More sharing options...
aesop Posted July 9, 2009 Author Share #5 Posted July 9, 2009 Hi, I use 8mm extension tube with 50mm lens on Focomat V35. I can manually focus without problems. ...super stuff, palec. Thanks for your support. Link to post Share on other sites More sharing options...
