Filter sizes
Guest BigSplash
Guest BigSplash
Can anyone point me in the direction of a list / web site of all M lenses that have been made and their respective filter sizes.?
I am looking at upgarding all of my lenses to "UV + IR" for the M8 ...is this really necessary or a waste of money.
I have at least the following issues:
> 50mm Noctilux (f1) Canada Mfg. ....It uses a 58mm but Leica do not make this.
> Somebody said using a filter on Noctilux is not a good idea? Comment?
> Apparently BH make the correct filter but who stocks it?
> 21mm Super Angulon (f3.4) Wetlar Mfg....what size is it?
> About 48mm as near as I can measure!
> 90 mm Summicron (f2) Canada Mfg. ..what size is it?
Viso Lenses
> Telyt 280mm...accepts a E58mm?
> Telyt 400mm..seems to have No filter thread..any idea why?
> Telyt 560mm ..seems to have no filter thread..any idea why?
> 65 mm Elmar (f3.5) ....seems a litlle larger than E39..maybe 42mm?
Still here Frank? Weather must be nice on the Promenade des Anglais no?
Do a search about IR-cut filters if you don't mind as it is an endless subject: http://www.l-camera-forum.com/leica-forum/search.php
Telyt 400 & 560: there is a filter slot at the rear of the lens IIRW.
Filter sizes depend on the vintage of your lenses so you'd better check their code number to be sure:
Noctilux 50/1, code # 11821, filter E58
Super-Angulon 21/3.4, code # 11103, filter S7/E48
Elmar 65/3.5, code # 11162, filter S6/E44
Summicron 90/2, code # 11123, filter E48
Summicron 90/2, code # 11136, filter E49
Summicron 90/2, code # 11136, filter E55
Telyt 280/4.8, code # 11914, filter S8/E66
Telyt 400/6.8, code # 11966, filter S7
Telyt 560/6.8, code # 11864, filter S7
Guest BigSplash
Thanks ...this is very helpful.
Too much wind today for photographing the crowd at Promenade des Anglais today ...gone sailing instead, but brought my laptop anyway while the below deck team cook!
Thanks again
Viso Lenses
Having had an interest in Leica since you were five I would have thought you would have this all memorized.:eek:
Guest BigSplash
I have had a lot on my mind since I was five, and I forget!
I have discovered that E means "Einschrauben" and (screw in) E39 would refer to the 39 mm diameter... Is the measurement of 39 mm across the visible glass or outside threads...does anyone know.?
I have not managed to find a list of lenses (serial nos) vis a vis filter sizes for M series lenses. Anyone have a link?
Above I note there are 3 separate filter sizes for 90 mm (f2) Summicron (old type..pre Apro) and I am unsure which refers to my lens (S/No 2659903 ..made in Canada)
Thanks for your help.
...Above I note there are 3 separate filter sizes for 90 mm (f2) Summicron (old type..pre Apro) and I am unsure which refers to my lens (S/No 2659903 ..made in Canada)...
Does your lens look like that? If so it is the code number 11123, the first one in my list above.
Guest BigSplash
Yes it does look like this and the rear face of the lens has a tripod mount...I guess as this lens does....The lens was bought new by me in 1976 .
I am told it is a classic...certainly the photos even in my hands is awesome and provokes questions about how good the new lenses really are in final result rather than less weight, smaller size.
Thanks for the feedback, much appreciated.
