Unfortunately, it is not a "250"...
Taking dust in my garage for many years, there was a black, heavy, reinforced carrying bag marked "DS&S". Looking for a tool, I opened it to rediscover a camera I had long forgotten : the Shackman Auto Camera Mk3. I bought it at a trade fair some 30 years ago because it reminded me the Leica 250, and also because, as a former pilot, I had always been interested in aerial cameras.
This one was produced immediately before, and during WW2 for the Royal Air Force.
I attach four pics (out of the twelve I shoot this afternoon with my Digilux 2), which are mostly self-explanatory. But let's add a few notes : on the sliding back plate displaying all camera's details, there is a mention evidencing that this "tool" could be used by not professional photographers : "WARNING. Do not operate camera without film" !!! On the identifying plate marked "Camera Type Nº 4757 etc..", there is an arrow pointing up which, like all Leica collectors know, means "R.A.F. Property". And finally, the maximum aperture of the Dallmeyer lens is not bad at 1.9, and its serial number (466/38) clearly dates the set at 1938.
Very interesting item !!! Thanks for the pics... seems there is an electric plug in the back... does it have an internal motor to cock/advance ? And... has the lens a focus adjustment or is it a fixed focus (has sense on a aerial equipment) ? The two front "tripod" screws seem intended to fit the body to some support... do youknow in which planes it was used ?
Nice Camera Pecole, interesting bit of history.....I wonder what secret German instalations that photographed during WW2?
The "broad arrow" designates Crown, not R.A.F. property. You find it on Army weapons and other kit too, including a WWI Colt .455 revolver I own.
The old man from the Age of the World Wars
Ohhh the "broad arrow" was also used on RAF equipment as well ~ all the original WW2 RAF Omega Wrist Watches have the broad arrow stamped on the back as well as service issue numbers :)
Tom
Yes, Luigi, there is an electrical motor in the base to advance the film, and most probably to actuate the shutter as well. And yes, the lens is a fixed focus one. As for the type(s) of plane(s) in which this camera was used, I did not investigate. But it must have been bomber(s), since most recce airplanes were high altitude single seaters, and fighters had much smaller cameras linked to the machine guns.
  • 2 weeks later...
There is no electrie motor in the base.This camera is powered by a spring wound motor which is wound by the shaft to the right of the mod. plate.The electrical connector operates a servo which fires the shutter and activates the winder.The camera can be fired manually by pushing the button below the removable back plate.The film is advanced by moving the lever(button in this case)next to the shutter release,to the right. The complete outfit includes 6 film cassettes as well as the winding key.
Thank you so much for theses precious informations, Robert. I was confused by the electrical parts I discovered when opening the left bottom plate. So, I realize my set is incomplete, the most important missing part being the winding key. If you have more details or pics, please let's share !
Cordially
Pecole (Pierre Jeandrain)
Tom
Yes Tom, Royal Army, Royal Air force and Royal Navy. The works. As I wrote: Crown Property.
The winding key is an ordinary clock winding key.If you find one that fits you can try the motor.The camera,in this configuration,was used to photograph instrument panels in aircraft test flights.The full set also includes a focussing eyepiece that replaces the backplate and enables you to colimate the lens to the required subject distance.There were also lenses with full focussing ability and a top plate with a parralax corrected viewfinder.
Thanks a lot, Robert. I'll try to find a suitable key !
