Possibility to completly turn off Noise Reduction on Long Exposures?
marmelade
A non-noise reduced image would be completely useless. There is no way to do this kind of noise reduction in the computer, it is a totally different principle. So turning it off would be the same as not taking the image. As said a few times before in this thread.
I think this is one of the downsides to the M9. There is currently no way to do a lot of long exposures without killing a battery. Unless I missed something and there is a battery extension pack somewhere?
No battery extension. It has been discussed here. If there had been adequate interest, then an entrepreneur would likely have offered such. There is a fast and convenient battery and SD change bottom available from Leicatime. Click on the left column under 'battery and sd changer'. (I plan to buy one to make working in sub-zero weather just a bit easier.)
The essence of Leica M design and use philosophy does not include some things, however it is remarkable (to me) that Leica included dark frame subtraction. For making many exceptionally long exposures I would look to a specialty camera.
I'm just wondering, how is it possible to get perfectly clean file from Nikon D40 at 30 min. exposures with NR Off - I could provide samples. D40 has the same type of sensor.
One approach is to have reference frames stored. For example, a 30-second dark frame to apply to any 30-second exposure. This approach is a compromise because dark noise depends upon environmental factors which would possibly change the hot pixels.
Look to astronomy photography sites for a great deal of such information.
CMos is completely different, as noise is equalized at readout by the on-sensor noisereducing circuitry.
If you want to avoid the time taken to record the 'dark frame' that's used to remove the effect of hot pixels then you could simply switch the camera off and back on once it starts recording the dark frame. You'll end up with hot pixels in the picture but that may be acceptable to you in certain circumstances.
This is the same technique I, I mean a friend of mine;), uses when he's taken a shot with his lens cap on and the camera sets the exposure to 32 seconds. The camera don't appear to mind at all.
Pete.
Thanks, jaapv! But I even more puzzled now: my D700 (CMOS) produced a lot of more noise at very long exposures even with NR=On than D40 (CCD) with no noise reduction...
