Best M8 lens focal length?
sm23221
In the opinion of past M Leica users, what is the one best focal length to purchase for street photography and landscapes. I realize there isn't one lens that will satisfy all situations, but if you could only buy one lens which would it be? Thanks.
  • Replies 54
  • Created
  • Last Reply
Tough call... For me, probably the 28 (equivalent to 37mm FoV), but the 24 (eff 32mm) would also be very good. If you like a more normal look, then the 35 (47mm) is a great choice. The 50 (67mm) becomes a bit tight for landscape IMO and the 21 (28mm) is getting a bit wide for all-around landscape; add the fact it needs an auxillary finder and it is ruled out totally for me.
My own personal three-lens short list is the 24 Asph, 35 Cron Asph and 50 Cron, but if I could only have one lens it would probably be the 28 (Cron Asph)...
My .02, YMMV
I will go for the Summicron 28 ASPH. Ist the best lens Leica produces (better than the 50mm Summicron!) and its the widest lens whoes frame you still can see in the viewer. At the M8 it will have the classical 35mm.
The second one would be a Summilux 50mm... for portraits
Probably the 28mm (scaled to a 35mm) for me.
By the way, I have a Voitlander 21mm/4 with an external finder. I guess the finder won't be appropriate anymore with 1.33 factor, right ? Will I be able to use the 28mm frames instead in the camera viewfinder ?
Thanks,
Luc
Thanks,
Luc
No, you'll need to get a 28mm external finder for the 21mm lens.
Cheers,
Stan
Please forgive what may be a silly question...
Can you not select the 28mm frames?
Not silly; it is confusing. The 28mm frame will show what a 28mm lens will cover given the 1.33 crop factor - they are not the same as the 28mm frame on an M7. In other words, the M8 28mm frame will show roughly the same field of view as 35mm frame on a full frame camera. This means the 21mm lens will have a larger field of view than that shown by the M8's 28mm frame.
Now I have confused myself......! But it is all true to the best of my understanding.
Chris
Chris
Thanks for your reply. I think I've got it now!
Just bought the 24mm in anticipation of the M8.
Line up is now:
24mm Elmarit Asph / 35mm Summicron Asph / 50mm Summilux / 90 Tele Elmarit M
With M8 / MP / M3 bodies that goes from very wide (24mm) to very long (eff 119mm) and from 0.7 metres to infinity using an outfit that will fit in a small case !!.
It also provides capture via from slide film, through B&W film to digital capture.
For one best lens, it would need to be a 35mm Summilux IMO. For what I want to do, a Summilux is required somewhere in the kit because it helps stay at lower ISO ratings and maintains the Leica wide aperture advantage over the competition.
Be interesting for Sean to compare wide open performance with regard to using the M8 v 5D at lower ISO ratings because of lens quality.
Transaction ID:0LD.......498...J
1-year ReidReviews.com subscription
The best focal length to use on any camera is what "paints" a field of view most closely corresponding to what your eyes are seeing at the moment.
We gravitate to the Leica M because we can't do otherwise: it's viewfinder places the least amount of annoying machinery between me and what my eyes are seeing.
I give flowers to my love because I can't help myself; I can't do otherwise.
-g
Guest guy_mancuso
I wish I knew the answer to this preplexing question what focal length. I bought them all to find out. 15,21,24,35,50,75,90,135. Okay i went WAY overboard but it will be fun figuring out what works and what don't . Just don't tell my wife:D :D :D
Feel like i am cheating here
What, no 28? How can you stand it? :D
Why is that info in your post? Everything OK with your subscription? Please e-mail me off-list.
BTW, my favorite focal length lens on the M8 so far is 28 mm but we're all different, of course.
Cheers,
Sean
