Help! Red dot fell off
NZDavid
  • Replies 43
  • Created
  • Last Reply
Red dot has fallen off my 24 Elmarit ASPH. I can see the indentation where it went but can't find the dot itself. Solutions?
These are typically obtainable from your Leica distributor or national service center. Since I don't believe Leica has staffed offices in New Zealand, you would probably want to direct your request to headquarters in Solms Germany, or you may want to try the designated sales agent for New Zealand, which is Lacklands Ltd in Auckland. Their contact information is available here: Leica Camera AG - Contact
Best of luck.
Jeff.
Solutions?
You have those downunder?
Ladybirds - a cute lens adornment. Thanks, I'll try Lacklands or Leica direct. How much for a red dot, do you suppose? I was wondering about a sticker or splodge of paint. At least I can see the mark -- I'd hate to misalign the lens.
David,
My recollection from others who have purchased replacement dots from Leica (either the red lens dot or the Leica wordmark dot for the front of the camera) is that the charge is very nominal --- probably a few dollars for a strip of them. Then you just use a dot of super glue.
Jeff.
Several years ago I had the same thing happen with my 35mm asph cron. I phoned or emailed Leica (USA) and they sent me a new one in the mail, without charge. I applied it with a drop of super glue (that cyanoacrylic stuff). I'm sure that a service center somewhere would send you a red dot or two.
Thanks for all your help. I'll try Leica for new one or even nail polish! Lens still works, of course (or do I need to buy a new one?), but dot does help align it correctly. Cheers, David
Call or write dave elwell, leica usa, and see if he can help you out. he it normally pretty helpful.. Look at leica site for e-mail write and ask them to forward to elwell or just speak to parts department
Guest stnami
Pretty sad state of affairs when a person cannot figure out what to do with a missing red dot. I wonder if taking a photograph is out of his league as it may be too complicated.......
I think somebody's red dot fell off a while ago! :(
Thanks again for all helpful replies, and I'll check out the link.
