Crystal Growth
Michael Hiles
Ece, Stuart,
Thank you both.
Regarding the frame, Ece is your comment specific to this picture, or a more general comment? I do these frames to produce an impression of a picture on the wall. This is how I mat and frame. Generally I like the look, but if I am a minority of one...
Hi Michael,
My comment is specific to this image. And, in a way addresses how I view an image on the wall vs. on the monitor. On the monitor, it usually works better for me if there is minimal distraction around the image, so those frames that don't distract (by proportional size and color choice) work well for me. For example, if you had this image framed with all black, at the same thickness, it wouldn't have distracted as much as the white (for me).
And, if I were to see this on a wall, it would be a totally different story, then I can imagine it being framed with a much wider white mat (than you have here) which would work very well. The gallery format even has some formulaic ratio of mat-to-image size, I think.
All the best,
Ece
