ronlayters Posted December 26, 2008 Share #1 Posted December 26, 2008 Advertisement (gone after registration) I've recently started having issues with my trusty R3 in cold weather (when it gets to zero degrees). When on auto mode the shutter stays open for around 4 or 5 seconds. It's as if the batteries are not working properly. I replaced the batteries but the problem still persists in cold conditions. Has anybody else experienced these problems? Is there an easy solution? I read somewhere that replacing the two silver oxide batteries with one lithium type might help, does anyone have experience of this? Thanks for any info Ron Link to post Share on other sites More sharing options...
Advertisement Posted December 26, 2008 Posted December 26, 2008 Hi ronlayters, Take a look here R3 not working in cold weather . I'm sure you'll find what you were looking for!
andybarton Posted December 26, 2008 Share #2 Posted December 26, 2008 Welcome to the forum, Ron! Changing the battery spec might help, but have you ever had the camera CLA'd? (Cleaned, Lubricated and Adjusted?) It sounds to me as if some of the oils and lubricants in the shutter mechanism are getting to thick in cold weather, and a service might be what's required. Link to post Share on other sites More sharing options...
earleygallery Posted December 27, 2008 Share #3 Posted December 27, 2008 Hmmm, is it ONLY happening in cold weather? What happens if you switch to manual operation? It's either the batteries (you may be unlucky with the recent ones you bought), lubricant as Andy as suggested, or a problem with the auto metering electronics. The latter could I think be checked by trying manual speeds in the same conditions, if the shutter works fine then I'd suspect the auto metering.... Link to post Share on other sites More sharing options...
Neil Purling Posted December 27, 2008 Share #4 Posted December 27, 2008 I had something like this happen when I had a Praktica BC1 many years ago. It was a matter of getting a higher spec battery, £5.50 as opposed to £2.38. Hope that the problem is as simple as that. Link to post Share on other sites More sharing options...
amoebahydra Posted December 29, 2008 Share #5 Posted December 29, 2008 I used to have R3 working under -14 degrees Celcius in 1982. Two things I had done to make it work: 1. Ask Leitz distributor to change all lubricant of the camera to low temperature type; and 2. I custom-made a battery extension cord from bottom of the camera to a battery holder inside inner pocket of my cloth to make it warm. Link to post Share on other sites More sharing options...
denzel1301 Posted December 31, 2008 Share #6 Posted December 31, 2008 Same thing with the R4. Just lubricate the DOF preview lever and it will be fine. I just got the same problem with my R4 in Yosemite last week and fixed it with lubricant. Link to post Share on other sites More sharing options...
