Digilux 2 website updated
Overgaard
  • Replies 43
  • Created
  • Last Reply
Do you have any problems with getting replacement/spare batteries since the camera has been 'out of production' ?
Digilux 3 batteries are said to work; I haven´t tried. And, officially the Digilux 3 isn´t yet "discontinued".
Besides, Leica usually stand behind their products. I don´t really expect them to discontinue the battery for a camera that they still repair under warranty.
There's third-part batteries as well, apart from the Panasonic and Leica batteries. I actually think I saw a Panasonic DMC-LC1 where the battery was Leica. Anyways, works for both cameras, no matter the brand.
But the trick is to buy more than one Digilux 2, because then suddenly you have a good stock of chargers and batteries ;-) - especially if the ones you buy comes with 2 batteries.
I just bought two brand new Panasonics "direct" for $40. each.
And you're right... it is nice to have a bunch lying around already charged.
JT
My one hope is that the 4/3 players will also start sharing the same battery apart from lens mount. The Olympus E-1 I bought recently has the exact same battery as the Digilux 2 (which uses the same battery as the Panasonic LC40/LC5/Leica D1), except for one simple detail: the contact point is different. Hence you can't share what is essentially the same thing between the two cameras. And the Olympus one is easier to find; cheaper, too. Grr.
Thorsten, superb homepage! Although I am by myself a little bit proud of my own Digilux 2 images, I am deeply impressed by your images! :o:)
I hope Leica will understand that the concept of this marvellous camera should be followed in the future.
Just a little hint for your homepage: Regarding the Digilux 2 stuff, I would write "Panasonic DMW-LW69 wide angle converter" instead of "wide angel"... ;)
Best regards,
Peter.
  • 1 month later...
The batteries are pretty standard Panasonic ones which are being used for some of their bigger models. It's the same one that was used in my Panasonic LC40 dating back 4 years ago, for example. Third party ones are hard to come by, though.
Thorsten, two questions about your excellent Digilux 2 site:
Your photo captions include a link to the file from the camera. When I point to that, I see a JPG. But a couple of them, including "Århus by Day - "Volden" AUTO, February 2004", also have links to a RAW file. Does this mean that the rest were taken as JPGs? Where there is a link to a RAW file, the "file from the camera" still points to a JPG. Does this mean the JPG file that's recorded along with a RAW exposure?
You show a picture of the Elpro macro lens, and say the "Panasonic DMW-LC69 may do as well but is no way the same lens." Of course it's not the same in manufacture, but is it not the same in another way? If so, how can the Panasonic do as well? I ask because the Elpro can be found sometimes, for about US$ 400, while the Panasonic is in stock at a few suppliers for US$ 65.
No, it's either RAW or JPG but those are from the original shoot which was the day before the D2 was officially released. So those were posted for interested to have a look at the high resolution original JPG files.
As for the ELPRO, I have that one but noticed Panasonic (as they always do), produces several different add-on lenses for DMC-LC1. How it does it for others to find out, but it's a macro lens of some sort.
The ELPRO is a cemented achromat in typical Leica style.
The Panasonic close-up lens is just that: A single-element close-up lens, just like what you get in a generic kit of +1, +2, +3 lenses.
I don't know the strength of the Panasonic, but it will likely be designed (as the ELPRO is) to start at about the close distance limit of the lens.
