DMR-Audio Histogram
jaapv
Jaap,
If you turn it on, it makes a chirp-chirp in case you overexpose.
Otherwise if it deems your exposure to be OK, it only makes two beeps.
I don't know how the DMR quantifies "overexposure"; you can only have a few small areas in your image that are overexposed and it des not chirp; so it acts fairly sensitive to overexposure, but tolerates a little bit. Not unreasonable.
Overall, a feature that is typical for medium format backs, so Imacon shines through on this feature.
I myself am still fighting with the "spot-metering"; I know it is a very large "spot-metering" area on the DMR compared to R9-film, but it still surprises me.
Peter
Thanks Peter. It seems a very useful feature. I use the DMR, amongst other things, for wildlife, and it is very nice not to have to take ones eye from the viewfinder in case action develops.
I know what you mean by the spot metering; I tend to use the matrix setting on the camera, as these are rapidly changing high-contrast situations.
Gentlemen,
It appears that you have failed to understand the audible exposure indication of the DMR.
When over exposure occurs the sequence of 'chirps' / 'bleeps' ascend in tone. When underexposure occurs the sequence of ‘chirps / bleep’ descend in tone.
A ‘double chirp / bleep’ indicates ‘on the limit’ exposure, but nothing to worry about. Very simple and very intuitive (I think).
The metering of the R8 / R9 is as good as it gets, but the audible histogram just provides extra backup for extreme exposure challenges.
The audio histogram enables the DMR user to use the camera more like a film camera as less time is spent checking the exposure on the camera back.
Why this feature was left off the M8 I don’t understand, but I am sure that a raft of M8 users will now advise me!
Happy snapping!
Mark
