A light meter question
Dear all,
Since my recent IIf purchase I got out my old but beautiful Euro-Master II light meter and used it for the first time in several years.I roughly calibrated it using my CL meter as a benchmark and the exposure readings I am getting are very accurate.
My question is, is there a 'lifetime' for these meters or will they essentially just keep working as long as they remain undamaged?
This feels like a stupid question as I write it:( but I would just like to know...no big deal, just curiosity.
thanks
andy
Dear all,
thanks
andy
I have its predecessor, a Weston Master IV which has given good service since 1962!
It has however had several new movements and cells in that time, they do have a finite life.
Gerry
For what I know (and for my experience too) there is a difference between "unpowered - no battery" meters (the old classical selenium lightemeters) and "powered - battery" meters (CdS and Silicon) : the selenium meters, based on the principle of photoelectric effect, do suffer time, but in terms of years: I have a Selenium Gossen Sixtino which is around 22 years old: still perfect; so is also my CdS Gossen Lunasix which maybe is some year older. On the contrary, I have an older again Selenium from Metrawatt (Voigtlander - branded, about 40 years old, shoe-mountable) which, some years ago started to die slowly... in 5-6 months it became less and less sensible to light. The powered meters, based on photoresistance effect, in my opinion can be "human-lifetime" , provided that have a good circuitry (to say, a switching system that powers the photoresistor only and strictly only during measurements... as I said, my Lunasix 3 is very very old... but I think that in 25 years or so its photoresistence was under Ampere flow for a effective total of.... 15 - 20 hours ?)
Hi Andy,
Maby this is some help?
Weston Master II Universal Exposure Meter Instruction Manual
regards
Ruben
I still use my little Gossen Pilot. It is genuine "Made in West Germany" quality. Uses no batteries. Bought it about 1965. It has not been abused & still works well under certain circumstances. Occasionally I check it against a gray card & compare it with my M6 meter. Also I check both Gossen & M6 against other makes. The little Pilot is spot on during any ordinary daylight setting. When the light fades after sunset, or indoors, it no longer reads accurately & I don't rely on it. Don't drop them, don't store in exteme heat or cold.
I recall reading somewhere that selenium meters should be stored with the cell exposed to light and that if left for long periods in darkness the efficiency of the cell deteriorates ... but this advice (I forget exactly where I read it) is contrary to that in the instructions.
If a selenium meter is used regularly then the cell might benefit from same and not get "tired" ??
Cheers
dunk
I have a Weston Master that was found in its case and box. It looks to be from the early 1940s. It is still accurate. I also have a Weston Master II found in the case that is also accurate. A lot has to do with how it was stored and how much it was used.
Guest flatfour
Selenium cells last a very long time. I still use my 1939 Sixtus. I have only had to adjust it once since I acquired it in 1981. Curiously enough I have never seen another with LEICA engraved on the face. It's a great bonus to be battery free using a Leica III and the Sixtus.
