Jon-Luke Posted May 16, 2008 Author Share #21 Posted May 16, 2008 Advertisement (gone after registration) Here's how to change your icons... Go the the icon you want to use (Some of the .icns files have no image - ignore these) select the icon you want to use and press "Apple - C" (Copy). Then go to the file/folder which you wan to apply the icon to. "ctrl - click" (Or right click) on this file/folder, a menu should pop up. Select the "Get Info" part of the menu. Now a window should open with the icon being used and the name of the file/folder at the top. Select the icon being used and then press "Apple - V" (Paste) the icon should change to the one you copied. For some files you have to repeat the "ctrl - V" two or three times to make it happen (I think this is a bit of an Apple glitch). One way to know that it is not going to work at all is if the icon changes to an icon that looks like a file with the letters ICNS in it. Then you know you need to start the whole process again. Hope this helps Link to post Share on other sites More sharing options...
Advertisement Posted May 16, 2008 Posted May 16, 2008 Hi Jon-Luke, Take a look here Icon for Mac . I'm sure you'll find what you were looking for!
spylaw4 Posted May 16, 2008 Share #22 Posted May 16, 2008 Thanks for the assistance, but I did get it to work via the approved method a couple of hours ago. So all is well now. Link to post Share on other sites More sharing options...
Overgaard Posted May 16, 2008 Share #23 Posted May 16, 2008 Open the two Get Info boxes along each other. Then click on the top icon (in the upper left corner) of the one you want to change [which 'activates' that] then click on the Leica symbol one [so as to activate that] than cmd-C (so as to copy it. Then go back to the other Get Info window where you have your icon 'activated', cmd-V that to paste it into. Should work, no? Link to post Share on other sites More sharing options...
cbretteville Posted May 16, 2008 Share #24 Posted May 16, 2008 I'm sending Windows versions of the icons to Thorsten, hopefully he'll make them available as well. - Carl Link to post Share on other sites More sharing options...
Overgaard Posted May 16, 2008 Share #25 Posted May 16, 2008 Thanks Bretteville, Got them and the site is up with both Windows and Mac icons now: leica.overgaard.dk - Thorsten Overgaard's Leica Pages - Leica icons for OSX and Windows Link to post Share on other sites More sharing options...
