vertekijker Posted April 3, 2008 Share #1 Posted April 3, 2008 Advertisement (gone after registration) A question I should have asked a loooooong time ago, but didn't.....When I want to bring a digital picture that I want to submit to the forum, to the required size, I use some sort of 'hit-and-miss' method in Photoshop till I get it right. Image size reducing, then saving at a lower quality, some more image size reducing, and a repeat of these steps if necessary, till I finally get to the permitted 244k. I am not that knowledgeable about Photoshop and was wondering if there are less time-consuming ways of proceding? How do you guys do this? Your answers are much appreciated, sincerely, Frans Link to post Share on other sites More sharing options...
Advertisement Posted April 3, 2008 Posted April 3, 2008 Hi vertekijker, Take a look here practical question . I'm sure you'll find what you were looking for!
jaapv Posted April 3, 2008 Share #2 Posted April 3, 2008 When I am lazy, I use the action Jack Flesher sells at DPI. When alert, I convert to 8-bits, set colour to sRGB, reduce size to 900 px wide, and run USM between 25 and 75 % at radius 0.4 threshold 0, then save as jPEG, quality to taste, baseline as needed. The jpeg save dialog will show the size of the file on the righthand side, about in the middle. Link to post Share on other sites More sharing options...
vertekijker Posted April 3, 2008 Author Share #3 Posted April 3, 2008 Thank you very much for your detailed explanation. Jaap. I'm taking notes! --------------------------------- Frans Link to post Share on other sites More sharing options...
johnwolf Posted April 3, 2008 Share #4 Posted April 3, 2008 Why not use File > Save for Web? Click the 2-Up tab at the top so you can see before and after images. Then adjust the Quality on the right until the size is what you want. You can see the file size at the bottom of the right-hand panel. You can also change the dimensions using the Image Size tab on the right. Link to post Share on other sites More sharing options...
mhoersch Posted April 3, 2008 Share #5 Posted April 3, 2008 I resize to 800px wide and save as JPG in Photoshop CS3, with quality set to medium (7), nothing else. Resulting size is always between 50 and 90 KB, quality more than enough for web. Link to post Share on other sites More sharing options...
vertekijker Posted April 3, 2008 Author Share #6 Posted April 3, 2008 Dear John and Manfred, More good tips! I will definitely try these new approaches. Thank you, Frans Link to post Share on other sites More sharing options...
