ejd Posted March 7, 2008 Share #1 Posted March 7, 2008 Advertisement (gone after registration) Can you use a flash on a IIIF or IIIG at low speeds? As you can on most cameras. E.g., with a IIIF R/D you are told to set the flash timing ring to 20 if you use 1/50 sec exposure or 0 if you use 1/25. But what do you do if you want a slower speed? 1/8, for example? Does the flash still work OK? The IIIG just offers you flash sync at what looks like 1/50 and 1/25. Link to post Share on other sites More sharing options...
Advertisement Posted March 7, 2008 Posted March 7, 2008 Hi ejd, Take a look here Flash at low speeds on IIIF or IIIG. I'm sure you'll find what you were looking for!
giordano Posted March 9, 2008 Share #2 Posted March 9, 2008 Can you use a flash on a IIIF or IIIG at low speeds? As you can on most cameras. E.g., with a IIIF R/D you are told to set the flash timing ring to 20 if you use 1/50 sec exposure or 0 if you use 1/25. But what do you do if you want a slower speed? 1/8, for example? Does the flash still work OK? The IIIG just offers you flash sync at what looks like 1/50 and 1/25. IIIg: set the main dial to the red lightning flash next to 1/30 sec and then set the slow speed dial to whatever you want. IIIf: if the 0 setting works at 1/25 it will probably work at all slower speeds. The IIIf manuals included a table showing the sync settings for different kinds of flash at different speeds; there's sure to be a copy on the internet somewhere. Or you can test it yourself: Take the lens off, dial the flash to its lowest power, and look at the film gate as you fire the camera. If you see the entire pressure plate or film surface, that's good; if you see all or part of a shutter blind, you've got the wrong setting. Link to post Share on other sites More sharing options...
ejd Posted March 9, 2008 Author Share #3 Posted March 9, 2008 Thanks for this. You're right -- I should try it out and see what happens. Rgds, John Link to post Share on other sites More sharing options...
earleygallery Posted March 11, 2008 Share #4 Posted March 11, 2008 John - in short it will work at slower speeds, but of course you need to bear in mind the ambient light and effect on exposure as well as movement (unless using a tripod). Link to post Share on other sites More sharing options...
ejd Posted March 11, 2008 Author Share #5 Posted March 11, 2008 James -- thanks. I will try it out. All the best, John Link to post Share on other sites More sharing options...
