31 minutes ago, rfunnell said:
Leica FOTOS App refuses to Pair with Q3-43 with the following error "Connection failed due to an unknown reason. Please restart camera and app and try again. Contact Customer care if the issue persists."
IOS version 262.2 and Q#-43 firmware is 4.0.0
Tried uninstalling Leica FOTOS App with same results.
Also deleted MEV1 camera on the App with the same results.
Any help appreciated.
I have solved my. problem while reading through these forums :)
The secret was to not only delete the camera's from the Fotos app but ALSO to
'Forget' the Bluetooth settings for the camera and then when ADDING them it all worked .
All good   now on with the new firmware.
5 hours ago, Tarekith said:
Press and hold down the right back button, this will show you a list of everything you can assign to that button.  You can also go into Customize Camera in the settings and remove all the things you don't want to appear in this list if you know they are things you'll never want to assign to a button.
Thank you, I had forgotten that.
vor 23 Stunden schrieb pathip:
After reading quite a bit and trying a few things, it looks like the solution is as simple as it is annoying—because it’s time-consuming.
Reset the camera and set it up again from scratch.
Probably the fix for a lot of the issues mentioned here.
The problem I described only occurs in the custom profiles I created earlier and carried over. The default profile is not affected.
So tonight I’ll probably have to bite the bullet and take the time to rebuild everything.
Still better than wasting even more time chasing the root cause and relying on half-baked workarounds.
Here‘s another problem I‘ve discovered:
In my case, I updated the Q3 43.
I was really excited about the announced new features and improvements—especially the autofocus improvements. However, I noticed that tracking people, faces, and eyes in combination with Continuous AF only works properly when using the camera’s rear display. As soon as I put my eye to the EVF, the AF starts to stutter, and in the viewfinder it looks like the AF is only tracking at around 2 FPS.
As soon as I switch back to the rear display and track a person, everything works smoothly as butter again.
Can anyone confirm this? Or does anyone have a tip on how to influence or fix this behavior?
WOW.  this is an interesting read.  I downloaded the new firmware a few days ago but have not had the time to install it.  So, today I started to read the last two days of comments.  I think I will pass on this one.  I like my favorites.  I don't want peaking in AF.  I don't like change, so was a bit apprehensive of the new menu layout but thought what the heck, but with all the other issues being discussed, I am not in any hurry to aggravate myself.  I would like faster boot time after along inactive period, but after some initial comments, not sure if this is a reality with 4.0.  I would like better tracking, but there seems to be some issues with this, too.
Thanks to all who have updated and commented.  Very helpful.
Hey,
I tested the fw 4.0 this morning and I can say: well done > this is the state of camera I would have wished from the beginning.
now I feel the af and I can react to it.
previous fw the af was jumping around a lot.
And there is more that I found very useful.
1. Startup time! Very good! Like it should be. Instant. (Pls make this on the M11 too)
2. wake up! Excellent
3. in play mode if you want to check the focus (zoomed into the image)  > you can now by keeping the play button pressed and scrolling with the thumbwheel you can now jump from image to image while the zoom level is kept. Very helpfull.
4. in Video > you can now use the camera on a gimbal! Top. Camera will also remote the exposure. In photo/video.
Only thing you can’t use and which would be helpfull is: if we could override the AF with the wheel of the gimbal that would be nice 👍 ( I us the rsc2) .
I am invited to a party today. So I will test the rest at this event.
But I like the feel of the camera very much.
very good job dev team!
if we could get that external trigger adapter for Timelapse I would be more than happy.
cheers Peter
No problem with freezes with the Q3 43 or SL3-S for me. Because basic menu functions had changed (in AF) I half anticipated problems with profiles that recorded old menu functions, so my first step was to re-save my old profiles. Perhaps this has let me off freezes. Switching between profiles is quick.
Nor did I need to delete Bluetooth pairs in phone Settings; I just deleted the connected camera in Fotos and reconnected.
I have used the Q3 43 for a couple of hours at a drama performance with no issues other than ignorance how AF was working: I hadn't thought through the changes properly, but I can see what Leica is trying to achieve now and will enjoy a bit more exploration today at a drama rehearsal with both cameras.
I would suggest that all of us not happy wit the focus peaking in AF/MF, portrait in replay etc etc email Leica at the following address
software-support@leica-camera.com
Just complaining here is not enough
Strangely my new Q3M which came with firmware v3.9 already had the issues of focus peaking in AF/MF and no portrait mode in playback. It already had  the new menu setup but v.4 has brought a few new tweaks that were not there in 3.9
I used to Beta test for Leica back when I was more into the system and was often taken back by some of the basic errors in firmware updates they were looking to release and found a couple of major issue back in the days of the M9 and M240
Edited by viramati
So far I have one niggle with the V4 update that I haven't seen anyone else noticing.
Before V4, focus peaking was only active in manual focussing in magnified mode, which was brilliant and I didn't feel the need to be able to switch peaking on or off. Now peaking is active when it's switched on, in magnified mode or non-magnified mode. I hope this will be changed back to pre-V4 functionality.
