J S H Posted November 29 Share #21 Posted November 29 Advertisement (gone after registration) On 11/27/2025 at 9:21 PM, SrMi said: In a brief test, M11 with 135 does not seem to be stabilized nor is the view smaller than the final result. Can you check again? Sorry, I don't need to check. I know the situation quite well. With the camera on a tripod and using live view (ideally with the EVF) put a small object, like a wire or possibly the tip of a branch right on the edge of the frame. Take a shot and then carefully review the image. After you do this a few times, you'll see that there is actually a bit more of the frame in the final image than appears in the live view feed. It's probably a little easier to sort through with a longer lens like a 50/75/90. 1 Link to post Share on other sites More sharing options...
Advertisement Posted November 29 Posted November 29 Hi J S H, Take a look here Perhaps M-EV1 is superior to m11 with visoflex! . I'm sure you'll find what you were looking for!
SrMi Posted November 29 Share #22 Posted November 29 29 minutes ago, J S H said: Sorry, I don't need to check. I know the situation quite well. With the camera on a tripod and using live view (ideally with the EVF) put a small object, like a wire or possibly the tip of a branch right on the edge of the frame. Take a shot and then carefully review the image. After you do this a few times, you'll see that there is actually a bit more of the frame in the final image than appears in the live view feed. It's probably a little easier to sort through with a longer lens like a 50/75/90. I can confirm the crop in both M11 with EVF and M-EV1. The easiest way to see the difference is to put the camera on a tripod, take an image, and then switch between live view and image review. 1 Link to post Share on other sites More sharing options...
Stevejack Posted 9 hours ago Share #23 Posted 9 hours ago On 11/30/2025 at 3:45 AM, SrMi said: I can confirm the crop in both M11 with EVF and M-EV1. The easiest way to see the difference is to put the camera on a tripod, take an image, and then switch between live view and image review. This issue took me by surprise when I noticed it too. Tree leaves and other distracting elements appearing on the edges of my photographs when I was sure I'd avoided them in the EVF. It's a bit annoying having to go in and crop images after already taking the time to frame the shot exactly as I wanted it in-camera. 1 Link to post Share on other sites More sharing options...
