As the title suggests, I am looking for experience in using an SL camera with IBIS for handheld macro photography (say, at 1:2 magnification). Is IBIS helpful in this situation? I never had a camera with IBIS and I cannot get a clear answer from the internet. I would be using a flash to freeze the picture. The question is whether IBIS would help for accurately framing the picture.
Edited by Photar
It works, but is less effective at very close distances.
Yes, IBIS works but as above, not very effective.
Macro without tripod is generally subpar, but doable but with a higher risk of ruined photos.
I did many many underwater macro shots and what i did to reduce unsharp photos is:
  • highest shutter speed what syncronize with the flash to block movement, mine or objects
  • f/16 or more to get most DoF what helps a tiny bit with micro movement
  • AFC to correct my or objects movement, do some tests if that works for you as it can be counterproductive
  • Auto ISO to handle correct exposure, ISO will not raise excessive as you have a flash
On land i carry mostly a mono or tripod, even if only one of those small ones and it's use is also for low light photos.
Chris
Edited by PhotoCruiser
  • Thanks 2
Yes, a lot better than doing it handheld, but not as well as with a tripod.
