Einst_Stein Posted 21 hours ago Share #1 Posted 21 hours ago Advertisement (gone after registration) I shoot a lot of travel architecture interior, churches, palace, etc. I used to use CL +11-23mm. Now I want to add super wide to M 240. I narrowed down to Laowa 15mm f2 and 14mm f4. Any experience with either or both? Your comment please. Link to post Share on other sites More sharing options...
Advertisement Posted 21 hours ago Posted 21 hours ago Hi Einst_Stein, Take a look here Laowa 15mm f2 or 14mm f4 for M 240 w EVF. I'm sure you'll find what you were looking for!
david strachan Posted 12 hours ago Share #2 Posted 12 hours ago Such wide angle lenses on the 240 will cause red edges in the image I suspect. Certainly does with my M-P and my Voigtlander 15 mm first version. I can remove it in post, but it is something to consider. 1 Link to post Share on other sites More sharing options...
PhotoCruiser Posted 11 hours ago Share #3 Posted 11 hours ago vor 45 Minuten schrieb david strachan: Such wide angle lenses on the 240 will cause red edges in the image I suspect. What are red edges? Chromatic aberration? Just for my personal education: Can you explain why 15/14mm will provoke them on the M240? The sensor? I thought CA comes (mostly) from the lens quality as my older Sigma 15mm f/2.8 diagonal fisheye created a lot of CA on my D800 while my Sigma 14mm 1.8 ART on the SL2 does not create any CA. Chris Link to post Share on other sites More sharing options...
Einst_Stein Posted 10 hours ago Author Share #4 Posted 10 hours ago (edited) 1 hour ago, david strachan said: Such wide angle lenses on the 240 will cause red edges in the image I suspect. Certainly does with my M-P and my Voigtlander 15 mm first version. I can remove it in post, but it is something to consider. I just returned Tamron 15-30mm f2.8 G2 (Nikon F mount adapted to M240) because of the lack of aperture control and the distortion. I but the “red edge” is not the problem, at least not something to stop the show. I have also Leica 11-23mm on CL, it works excellent on CL. I think you can feel good about this concern. There are at least two 15mm lenses people like on M digital, a Zeiss and a Voigtlander. Laowa 14mm and 15mm Zero-D are comparable or even better than the two in some of the performance. Between the two M mount Zero-D, 14mm is lighter, slower, and 15mm might be slightly sharper, but I am not sure how they compare in the real usage. Edited 10 hours ago by Einst_Stein Link to post Share on other sites More sharing options...
AceVentura1986 Posted 8 hours ago Share #5 Posted 8 hours ago 3 hours ago, david strachan said: Such wide angle lenses on the 240 will cause red edges in the image I suspect. Certainly does with my M-P and my Voigtlander 15 mm first version. I can remove it in post, but it is something to consider. Excuse my ignorance, but how would you go about removing the red edges in post. I’ve got an M10P and the CV 15mm Heliar. Now, I’ve never actually shot this lens on the M10P but I did get the red fringing on my old M9. Link to post Share on other sites More sharing options...
Einst_Stein Posted 7 hours ago Author Share #6 Posted 7 hours ago 1 hour ago, AceVentura1986 said: Excuse my ignorance, but how would you go about removing the red edges in post. I’ve got an M10P and the CV 15mm Heliar. Now, I’ve never actually shot this lens on the M10P but I did get the red fringing on my old M9. If you mean CA, try Lightroom lens correction. But I hope you are not mentioning the focus leaking, which can show red edge on the objects that are in focus. Link to post Share on other sites More sharing options...
