Viktor Long Posted 14 hours ago Share #1 Posted 14 hours ago Advertisement (gone after registration) I have a Leica m8, and in need for correct color, I use uvir filter, I always use 35mm lens so there is no obvious color shift in corner. Now, for some reason, I want to use ND filter for high speed flash sync, or use black diffusion filter. I want to know if the uvir will cause wrong results when use two filter together? Will the use of multiple filters at the same time cause a decrease in image quality? Link to post Share on other sites More sharing options...
Advertisement Posted 14 hours ago Posted 14 hours ago Hi Viktor Long, Take a look here Can Leica M8 use UVIR and ND/or black diffusion filter in same time?. I'm sure you'll find what you were looking for!
Viktor Long Posted 14 hours ago Author Share #2 Posted 14 hours ago 刚才,Viktor Long说: 我有一把徕卡m8,需要正确的颜色,我使用uvir滤镜,我总是使用35mm镜头,所以角落没有明显的颜色变化。现在,出于某种原因,我想使用ND滤波器进行高速闪光同步,或者使用黑色扩散滤波器。我想知道当两个过滤器一起使用时,uvir是否会导致错误的结果?同时使用多个滤镜会导致图像质量下降吗? If it is okay to use multiple filters at the same time, should I put the uvir closest to the lens or the farthest away from the lens? Link to post Share on other sites More sharing options...
jdlaing Posted 8 hours ago Share #3 Posted 8 hours ago I never stacked filters. You may get vignetting or unwanted color shift. 1 Link to post Share on other sites More sharing options...
farnz Posted 8 hours ago Share #4 Posted 8 hours ago You might get some mechanical vignetting where the stacked filter rings reduce light in the corners of the picture. This can be resolved by using a step-up ring and larger filters. It shouldn't matter which filter you put next to the lens. Pete. Link to post Share on other sites More sharing options...
