Hi
I am buying a used M monochrom typ 246. It comes with only 1 battery. I know that there are problem finding a spare battery.
So I was thinking: are there battery packs I can use to recharge the battery when traveling? Or any other solution to quickly recharge the battery?
Thanks.
Go to the Leica store in your city, and order a battery. They will know better than anyone about availability, etc.
The battery life is really quite long and will last you for much longer than any normal outing.
Address: Kuttelgasse 4, 8001 Zürich, Switzerland
On 10/4/2025 at 11:31 PM, wolan said:
Hi
Thanks.
Nitecore charger works well and runs off of USB power so very flexible - but NOT fast - the Leica charger would be faster
I have the NiteCore USB charger for my BP-SCL4/6 batteries and it works well.
Not the fastest but should work off a power bank, if you want to be sure i would need to make a test, let me know if so.
Chris
The Leica charger also has a 12 v input and I used it often to charge the batteries while driving with the car from the cigarette lighter.
Due to lack of adaptors I haven't tried it with a power bank yet.
