Hello everyone. Here are some photos of my Summicron 35, without a serial number. It looks like an 8-piece Leitz made in Canada. Is there any way to find out its build date? Thanks.
This lens seems to be made in Germany, as the Canada lenses have "LEITZ CANADA" on the front ring, see photos in the wiki, yours is Wetzlar.
https://wiki.l-camera-forum.com/leica-wiki.en/index.php/Summicron_(I)_f%3D_3.5_cm_1:2
The missing serial number is remarkable though.
The 8 Element Summicron was made with 10 or 16 blades, yours is a 10 blade. Maybe this indicates an early (< 1963) version, but I am not sure.
Edited by dg4mgr
Apart the lack of s/n, the LENS MADE IN CANADA is someway an oddity... 8  elements lenses, afaik, usually have "Germany" or "Canada" in Italic fonts... though Lager  displays # 2286131 with such a writing or it's a sort of prototype, or a 3rd party rework, and this is imho more probable
What is the minimum focus distance ? I wonder if it could be, originally, a screw mount item.
Edited by luigi bertolotti
My opinion is that  lens is assembled by a Leitz employee from an "attrape" lens, I have some in my collection, also "attrape" cameras were rebuild with spare parts and woks...
An example :
Very reasonable hipotesis, JC... or maybe simply a Canadian worker who assembled his own Summicron with parts he found someway "disposable"...
I agree, Luigi. It is either that or a repair job. I’m sure the lens works perfectly well.
William
vor 23 Stunden schrieb luigi bertolotti:
As those are even more valuable, I much doubt that someone would convert an original screw mount lens into an M mount lens.
You can check the minimum focus distance. 1 metre for LTM, 0.7 for M.
William
That's true, but nowadays ,or anyaway when collecting became a businness of its own... but if the lens was manufactured in a "artisan" way, with "casually available" parts at the Ontario factory, this factor was unsignificant.
Adjunto fotos para aclarar algunos comentarios, lo cual agradezco. Probé este Summicron con una Epson R-D1 y obtuve muy buenos resultados.
Hi Luigi, I got some testimony from the daughter of a former Leitz Wetzlar employe that his father "made a lot of pictures with the camera and lens" you can see on the picture.
I believe it when I got the combo....
