ApoVision Posted July 28 Share #1 Posted July 28 Advertisement (gone after registration) Does anyone have information about when Leica started to replace "No" sign (the "o" being underlined) before the serial number on the top plate with "Nr."? A cursory google image search seems to insinuate that this must have been around 1950 (No 500 000). Also, whereas most "Monté en Sarre" (1949 - 1951) have the "No" sign, there is some usage of "Nr." (359 122; 359 495; 359 312) Is such a "naming convention" one of these things where Leica potentially paid less attention and where there existed no clear SOP? Or - is there an informed decision that was consistently applied (which I may not be able to see)? Thanks for your help. Link to post Share on other sites More sharing options...
Advertisement Posted July 28 Posted July 28 Hi ApoVision, Take a look here Serial number patterns of screw mount Leicas - use of "No" vs "Nr". I'm sure you'll find what you were looking for!
UliWer Posted July 29 Share #2 Posted July 29 I don‘t think you‘ll find a precise number on a lens where the engraving with „No.“ stopped and „Nr.“ started. Lager lists (but does not show) a 13.5cm Hektor 824421 and a 9cm Elmar 873054 with No. Though he also shows a 5cm Summarit 491931, a Summitar* 812276 and a 12.5cm Hektor 753029 with Nr. One reason for this „inconsistency“ is that the lens production did not happen in a strictly numerical sequence. Numbers were assigned to a certain batch of lenses (or cameras) in advance and it happened that later batches of different items - with higher numbers - were produced earlier than batches with lower numbers. You‘ll see the same mixture of numbers with lenses engraved with cm or mm. Link to post Share on other sites More sharing options...
jerzy Posted July 29 Share #3 Posted July 29 vor 4 Stunden schrieb UliWer: One reason for this „inconsistency“ is that the lens production did not happen in a strictly numerical sequence same for the cameras. We need to take into consideration that cameras were sometimes repaired, replacing top cover and this could falsify the findings. Like example below - all cameras on the left are stepper IIIc, 379577 was not upgraded to IIIcf but I believe that the top cover has been replaced early 50-ties, when spare stepper top covers were still available and serial was engraved then. Right photos show very early non-stepper and later sharkskin, both still with No Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Some estimate when switch happened can be seen here, but more examples are needed to be quite sure about when it was (1951/52) 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! Some estimate when switch happened can be seen here, but more examples are needed to be quite sure about when it was (1951/52) ' data-webShareUrl='https://www.l-camera-forum.com/topic/423340-serial-number-patterns-of-screw-mount-leicas-use-of-no-vs-nr/?do=findComment&comment=5840447'>More sharing options...
ApoVision Posted July 30 Author Share #4 Posted July 30 Thank you all - very helpful. My perliminary hypothesis is: Leicas that have not been converted and Leicas the top plate of which was not changed usually have the "Nr." sign if their serial number is >= 500 000; otherwise they usually have the "No" sign. Photos are from Leitz-Auction (thanks!). Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/423340-serial-number-patterns-of-screw-mount-leicas-use-of-no-vs-nr/?do=findComment&comment=5840687'>More sharing options...
UliWer Posted July 30 Share #5 Posted July 30 1 hour ago, ApoVision said: My perliminary hypothesis is: Leicas that have not been converted and Leicas the top plate of which was not changed usually have the "Nr." sign if their serial number is >= 500 000; otherwise they usually have the "No" sign. No. 537781 shown by jerzy in #3 seems to contradict your hypothesis. For lenses the engraving seems to depend on the lens types. Lager shows a very early Hektor 1:2.5/12.5cm 753029 with Nr. but assigns „No.“ to a Summarex 1008349 (though unfortunately the lenses front is not shown). Link to post Share on other sites More sharing options...
jerzy Posted July 30 Share #6 Posted July 30 vor 9 Stunden schrieb ApoVision: "Nr." sign if their serial number is >= 500 000; otherwise they usually have the "No" sign. Leica 500 000 is a special case, cameras with similar special numbers were usually presented to "special" people, they were produced whenever there was a need to honour the person, these numbers were taken out from regular production Link to post Share on other sites More sharing options...
ApoVision Posted July 30 Author Share #7 Posted July 30 Advertisement (gone after registration) thank you; will look for additional numbers greater 500k Link to post Share on other sites More sharing options...
ApoVision Posted July 30 Author Share #8 Posted July 30 9 hours ago, UliWer said: No. 537781 shown by jerzy in #3 seems to contradict your hypothesis. For lenses the engraving seems to depend on the lens types. Lager shows a very early Hektor 1:2.5/12.5cm 753029 with Nr. but assigns „No.“ to a Summarex 1008349 (though unfortunately the lenses front is not shown). Sorry for dissenting, I used the word "usually" in the sense of "statistically significantly", "more often than not", not: "always". Thanks Link to post Share on other sites More sharing options...
UliWer Posted July 30 Share #9 Posted July 30 Yes, of course! Statistically there are more items with „Nr“ than with „No“ if the engraving was changed with Nr 540 000 (approximately). Your hypothesis is very well founded. Link to post Share on other sites More sharing options...
