kenf Posted June 17 Share #1 Posted June 17 Advertisement (gone after registration) I recently received a like new condition SL2. Is there any way I can determine the condition of the battery? I can’t find anything in the settings like some cameras have, and the charger is pretty basic. I know initial setup and familiarization will burn through a charge, but it seems like I am getting less life than I expected. Link to post Share on other sites More sharing options...
Advertisement Posted June 17 Posted June 17 Hi kenf, Take a look here Any way to determine BP-SCL4 battery health?. I'm sure you'll find what you were looking for!
frame-it Posted June 18 Share #2 Posted June 18 1 hour ago, kenf said: I recently received a like new condition SL2. Is there any way I can determine the condition of the battery? I can’t find anything in the settings like some cameras have, and the charger is pretty basic. I know initial setup and familiarization will burn through a charge, but it seems like I am getting less life than I expected. 1 Link to post Share on other sites More sharing options...
kenf Posted June 18 Author Share #3 Posted June 18 That will check voltage, but not capacity. 1 Link to post Share on other sites More sharing options...
darylgo Posted June 18 Share #4 Posted June 18 The SL2 is a battery hog despite the batteries size. My two used batteries from previous owners are fine. Leica released a larger capacity battery. Link to post Share on other sites More sharing options...
jdlaing Posted June 19 Share #5 Posted June 19 To determine a battery's capacity, a discharge test is commonly used. This involves discharging the battery at a known current and measuring the time it takes for the voltage to drop to a specified level. The capacity is then calculated by multiplying the current by the time. Another method involves measuring the amount of charge removed from the battery during a discharge cycle. Link to post Share on other sites More sharing options...
frame-it Posted June 19 Share #6 Posted June 19 (edited) 21 hours ago, kenf said: That will check voltage, but not capacity. i think a nitecore charger shows the "health" of the battery? if you get one, make sure its plugged into a proper power source Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited June 19 by frame-it 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/422263-any-way-to-determine-bp-scl4-battery-health/?do=findComment&comment=5820421'>More sharing options...
jaapv Posted June 20 Share #7 Posted June 20 Advertisement (gone after registration) Indeed it does, in this clip the batter condition is “good” IMG_8614.mov 1 Link to post Share on other sites More sharing options...
kenf Posted June 21 Author Share #8 Posted June 21 (edited) All the Nitecore chargers I’m immediately seeing are for AA sized cells - I assume they have universal models too? I can see one of those being a useful tool. Edit: I just found they have Leica battery specific models. Perfect - thank you! Edited June 21 by kenf Link to post Share on other sites More sharing options...
frame-it Posted June 21 Share #9 Posted June 21 15 minutes ago, kenf said: All the Nitecore chargers I’m immediately seeing are for AA sized cells - I assume they have universal models too? I can see one of those being a useful tool. just make sure its plugged into a "proper" power source, not underpowered as many people did in the early days and complained it aint working Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/422263-any-way-to-determine-bp-scl4-battery-health/?do=findComment&comment=5821319'>More sharing options...
kenf Posted June 21 Author Share #10 Posted June 21 I have a BP-SCL2 that won’t take a charge with either the original Leica charger nor a cheap “dumb” charger that I picked up. I wonder if one of these would trick it into complying… Link to post Share on other sites More sharing options...
jaapv Posted June 22 Share #11 Posted June 22 I would not risk it. Such a battery if revived will always remain a fire hazard. Or - more common- it might swell up and get stuck in the camera. With Li-ion batteries dead=dead. Link to post Share on other sites More sharing options...
kenf Posted June 22 Author Share #12 Posted June 22 5 hours ago, jaapv said: I would not risk it. Such a battery if revived will always remain a fire hazard. Or - more common- it might swell up and get stuck in the camera. With Li-ion batteries dead=dead. I work with a lot of non-camera Li-ion batteries, I’m not worried about fire hazard - but swelling is definitely a consideration. Link to post Share on other sites More sharing options...
kenf Posted June 23 Author Share #13 Posted June 23 The M240 battery is moot - it won’t take a charge with the Nitecore charger, either. Luckily I now have two more batteries, one for my MP240 and the other for my M246. Link to post Share on other sites More sharing options...
laowai_ Posted June 29 Share #14 Posted June 29 On 6/18/2025 at 7:18 PM, jdlaing said: To determine a battery's capacity, a discharge test is commonly used. This involves discharging the battery at a known current and measuring the time it takes for the voltage to drop to a specified level. The capacity is then calculated by multiplying the current by the time. Another method involves measuring the amount of charge removed from the battery during a discharge cycle. What you are looking for is a SoH (State of Health) test. You can get a decent guess of the SoH of a battery pack by using a smart charger. If you need accuracy, precision and repeatability, measuring SoH of a battery pack is not trivial. Battery chemistry heavily depends on the state of charge (SoC) and the temperature. Charge/discharge tests are one method to estimate the state of health of a battery pack. Other methods are ACIR (AC internal resistance), tests used in battery production, DCIR (DC internal resistance) test used in EoL testing, OCV (open circuit voltage) test and k-value test used in battery production, EIS (Electrochemical Impedance Spectroscopy) used primarily in battery R&D. All of these tests require specialized skills and expensive test equipment. 2 Link to post Share on other sites More sharing options...
