tjphoto Posted June 7 Share #1 Posted June 7 Advertisement (gone after registration) Just curious if it’s possible to use Leica S central shutter lenses with high shutter synch speeds on sL3. Some of you guys must know . It would really be a nice trick to have in the bag. Thanks. Link to post Share on other sites More sharing options...
Advertisement Posted June 7 Posted June 7 Hi tjphoto, Take a look here Anyway to use high speed flash synch with S cs lenses on SL3?. I'm sure you'll find what you were looking for!
ynp Posted June 8 Share #2 Posted June 8 Not possible. Link to post Share on other sites More sharing options...
Nick Guttridge Posted June 8 Share #3 Posted June 8 I have asked Leica about this, because the fuji GFX has an adapter to use Hasselblad lenses which has a button which allows you to use the CS shutter on them. It's an oversight of Leica not to design an adapter which has something similar. 1 Link to post Share on other sites More sharing options...
davidmknoble Posted June 11 Share #4 Posted June 11 On 6/8/2025 at 4:36 AM, Nick Guttridge said: I have asked Leica about this, because the fuji GFX has an adapter to use Hasselblad lenses which has a button which allows you to use the CS shutter on them. It's an oversight of Leica not to design an adapter which has something similar. It's likely a power issue. The central shutter on the S lenses needs power to work it and the S batteries were larger. I don't know the layout of the pins on the SL or the S system, but it may just be incompatible. The CS also works differently from the Hasselblad and other older CS lenses. It opens before the shutter starts, the shutter opens, then the CS closes and the camera shutter closes. The system was designed to work with the S camera and the SL system may just not have what it needs to do all those things. Leica has made some incredible adapters. The L to R adapter reads the ROM information and gets the f/stop and the focal lenght of the zooms. I'm sure they would have added the CS shutter if it was reasonably feasable. 2 Link to post Share on other sites More sharing options...
