Fernando Mattos Posted May 14 Share #1  Posted May 14 Advertisement (gone after registration) Hi! I've just developed my first roll of a iiia and a iiif I just bought. The iiia was in poor condition, but working, and had less issues in the photos. The iiif was in pristine condition, professioned CLA a couple years ago, but had horizontal dark streaks in almost half the frames, randomly. 1) here are the defect in the iiif photos. I've had two consequent photos that one is like this, and the other is normal. FIY, I shot a rewinded double x. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members!  2) with the iiia i shot a Ilford hp5, and I had none of these black streaks, but I had consistent horizontal black fine lines in the final photos. Sometimes they seem equispaced. Here a zoom stripe of a photo that show those lines And here againg. It's, in a less or mre degree, in all frames.  Any thoughts on what might be causing thoses problems? In the iiif seems a problem with the curtain shutter, but I don't know how bad is it to fix. in the iiia I have no idea... Link to post Share on other sites Simply register for free here – We are always happy to welcome new members!  2) with the iiia i shot a Ilford hp5, and I had none of these black streaks, but I had consistent horizontal black fine lines in the final photos. Sometimes they seem equispaced. Here a zoom stripe of a photo that show those lines And here againg. It's, in a less or mre degree, in all frames.  Any thoughts on what might be causing thoses problems? In the iiif seems a problem with the curtain shutter, but I don't know how bad is it to fix. in the iiia I have no idea... ' data-webShareUrl='https://www.l-camera-forum.com/topic/421252-iiia-and-iiif-first-rolls-what-has-happened/?do=findComment&comment=5802037'>More sharing options...
Advertisement Posted May 14 Posted May 14 Hi Fernando Mattos, Take a look here iiia and iiif first rolls - what has happened?. I'm sure you'll find what you were looking for!
TomB_tx Posted May 14 Share #2 Â Posted May 14 The IIIf needs the shutter curtain speeds adjusted for use at high shutter speeds, as it looks like the closing curtain is catching up with the opening curtain part way across the frame. The dark streaks are due to the roughness of the edges of the curtain ends shading the film as the gap between the curtains narrows. At high shutter speeds there is a very narrow slit between the curtains and it doesn't take much drag to cause things like this. The camera may well be fine at slower shutter speeds, so you can try stopping the lens more and using slower speeds and see how that works. if you use (exercise) the camera a lot it's possible that the condition will improve. (You can try this without film, just keep winding and tripping at various speeds.) The few fine lines on the IIIa look like scratches on the film back side. Hard to identify the cause - it can even come from wiping the film in processing. Link to post Share on other sites More sharing options...
jerzy Posted May 14 Share #3  Posted May 14 vor 23 Minuten schrieb TomB_tx: The few fine lines on the IIIa look like scratches on the film back side. Hard to identify the cause - it can even come from wiping the film in processing. it could be as well film pressure plate. Without a film, open shutter at T and check if you see any scratches Link to post Share on other sites More sharing options...
Fernando Mattos Posted May 14 Author Share #4  Posted May 14 Thank you, @TomB_tx and @jerzy! I'll follow your advices Link to post Share on other sites More sharing options...
qqphot Posted May 14 Share #5 Â Posted May 14 The first two of your photos were probably shot at a fast shutter speed, where the curtain gap is narrow, and so unevenness in the curtain edge becomes visible in the photo as it accounts for a larger fraction of that narrow gap. In addition, the gap is uneven, becoming wider from left to right on the final image, indicating that the curtain tensions are not correctly adjusted. My experience with more than one of the usual leica CLA guys has been that unless you specifically request it they don't necessarily return them with the curtain tensions adjusted very accurately, or perhaps they don't remain accurate during shipping, or something. Â Link to post Share on other sites More sharing options...
Fernando Mattos Posted May 14 Author Share #6 Â Posted May 14 24 minutes ago, qqphot said: The first two of your photos were probably shot at a fast shutter speed, where the curtain gap is narrow, and so unevenness in the curtain edge becomes visible in the photo as it accounts for a larger fraction of that narrow gap. In addition, the gap is uneven, becoming wider from left to right on the final image, indicating that the curtain tensions are not correctly adjusted. My experience with more than one of the usual leica CLA guys has been that unless you specifically request it they don't necessarily return them with the curtain tensions adjusted very accurately, or perhaps they don't remain accurate during shipping, or something. Â Hum, good to know! I'll eventualy have it serviced, and then I'll specify this issue. Till then, I'll keep using a bit slower speed to avoid the issue, testing the higher eventualy to check if it persists. Link to post Share on other sites More sharing options...
Fernando Mattos Posted May 14 Author Share #7 Â Posted May 14 Advertisement (gone after registration) Nice to have you all here to help! Thanks again! Link to post Share on other sites More sharing options...
