Short of sending my Q to Leica, what do you suggest?
x
41 minutes ago, markie linhart said:
The rubber surround cannot be replaced on its own, Leica will replace the complete EVF. How do I know this? I went through this exercise myself…✌️🇦🇺
German engineering.  When my GT3 had the rear view mirror come loose the only solution was to replace the entire windshield.  I guess all the engineers over there went to the same university.
  • Haha 3
11 hours ago, stuny said:
The rubber surround of the eye level viewfinder has split and is partly swinging free in the breeze.
I'd use contact cement.  Coat both surfaces very lightly. Let them dry for 5 - 10 minutes depending on the glue's container instructions and then press together.  Any glue that has squeezed out can be trimmer with a very sharp paring knife or razor blade.  And you can still spin yarns about war wounds and having it repaired in the bazaar of some Middle Eastern war zone.  Take you pick.  And get an old Army field jacket to wear when shooting.  It will add to the glamour.  Yes!   ;o)
On 12/21/2024 at 3:45 AM, keithlaban.co.uk said:
I'd just be happy with an EVF that was function over form and prevented stray light!
It still functions as it should
14 hours ago, discoman5 said:
is it under warranty ?
It's 7-years old, so no it's out of warranty
If your Q is in very good condition, generally, then I’d be tempted to bite the bullet and send it to Leica via the nearest Leica store. You’d get the EVF replaced and, possibly, Leica would service it as well.  It would be worth it - to me.  If that’s not an option for you, my second choice would be to research the available glues and cements (as boojum suggests, above), prepare properly, and be bloody careful.
Good luck 🤞🏼 👍
