ioiooi Posted December 6, 2024 Share #1  Posted December 6, 2024 Advertisement (gone after registration) I have noticed a percievable shutter lag when using the SL3 with the Profoto Connect Pro and a Profoto B2 light. I am referring to an addition delay when comparing the time for shutter actuation when using and not using the flash trigger. Changing the flash sync setting in camera from start to end does not make any differences. I tested using shutter speeds between 1/160 up to 1/200 (max sync) and beyond using Hi-speed sync also does not make any differences. Can anyone else confirm this? Link to post Share on other sites More sharing options...
Advertisement Posted December 6, 2024 Posted December 6, 2024 Hi ioiooi, Take a look here SL3 - Shutter lag with Profoto Connect Pro. I'm sure you'll find what you were looking for!
Photoworks Posted December 6, 2024 Share #2 Â Posted December 6, 2024 It is the TTL pre-flash That is why I use a trigger in the studio that is not for Leica or turn on the Legacy setting. 1 Link to post Share on other sites More sharing options...
LocalHero1953 Posted December 6, 2024 Share #3 Â Posted December 6, 2024 There is another thread somewhere that reports the same thing, with quite a lot of detail. Link to post Share on other sites More sharing options...
ynp Posted December 6, 2024 Share #4  Posted December 6, 2024 TTL is evil. One pin trigger is not. 😉 Link to post Share on other sites More sharing options...
Dr. G Posted December 6, 2024 Share #5  Posted December 6, 2024 Not Profoto, but Godox nano for Leica on the SL3. Same thing, in TTL mode it has a delay sometimes and other times the shutter won't release at all. Legacy mode never fails with it, though. Link to post Share on other sites More sharing options...
LocalHero1953 Posted December 6, 2024 Share #6 Â Posted December 6, 2024 Here's the thread about Profoto. May not be directly related: using the Q3 and HSS - but perhaps indicative of Leica and Profoto not being quite on the same wavelength. Link to post Share on other sites More sharing options...
ioiooi Posted December 6, 2024 Author Share #7 Â Posted December 6, 2024 Advertisement (gone after registration) Thank you all for clearing that up. Cheers! Link to post Share on other sites More sharing options...
