SimoneRossi Posted November 21, 2024 Share #1 Posted November 21, 2024 Advertisement (gone after registration) Hello everyone, My Leica iiif Red dial Sync flash at 1/25 shutter works with 20 of delay and at 1/50 shutter works with 11 of delay, while everyone says 1/25 with 0 delay and 1/50 with 20 delay. i tried with different electronic flashes. do you know why? Link to post Share on other sites More sharing options...
Advertisement Posted November 21, 2024 Posted November 21, 2024 Hi SimoneRossi, Take a look here Leica IIIF Red dial flash Sync . I'm sure you'll find what you were looking for!
jc_braconi Posted November 21, 2024 Share #2 Posted November 21, 2024 Hello, Do you think a Leica IIIf is synchronysed for electronic flash ? Certainly a candid question Link to post Share on other sites More sharing options...
jerzy Posted November 21, 2024 Share #3 Posted November 21, 2024 (edited) vor 2 Stunden schrieb SimoneRossi: do you know why? hidden under the speed dial there is a sleeve/cam. It is fixed on shutter drum, rotates when shutter opens and closes contact for flash. If this sleeve is not correctly mounted it will not close the contacts when they shall be. Setting for electronic flash is 0 respectively 20, but if the cam is mounted incorrectly you will need to set differently to get flash sync when shutter is fully opened. As you may see on the left drawing, setting another contact number will rotate the contacts. What need to be done to get it correctly is to take off the speed dial, loosen the 3 screws fixing sleeve/cam and reposition it. Possibly you will need help of repair shop, if you want to do it by yourself you may download IIIf repair manual where the drawings came from Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited November 21, 2024 by jerzy Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/417336-leica-iiif-red-dial-flash-sync/?do=findComment&comment=5707268'>More sharing options...
jankap Posted November 21, 2024 Share #4 Posted November 21, 2024 (edited) The duration of an electronic short is very short. So the shutter must be fully open. Here is a copy from my manual. It says at the end of the table: electronic flash at either number 0 together with 1/25 or at 20 then with 1/50. I suppose, that the 1/25 is not critical in behave of the delay. Remember, that these cameras are around 70 years old. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited November 21, 2024 by jankap Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/417336-leica-iiif-red-dial-flash-sync/?do=findComment&comment=5707300'>More sharing options...
GregNski Posted November 21, 2024 Share #5 Posted November 21, 2024 I used to use my IIIf Black Dial with a setting of 2 at 1/30 sec with an electronic flash and never had a problem. Link to post Share on other sites More sharing options...
