uaqpau Posted November 12, 2024 Share #1 Posted November 12, 2024 Advertisement (gone after registration) Hello guys. I'm considering buying the Q3 but I have this doubt that, after looking everywhere, I still couldn't figure out. When you set the camera to 15fps continuous drive, is it still using the mechanical shutter or that speed is only possible with the electronic one? I'm asking because sometimes I need to shoot at that speed, but dont want the rolling shutter effect of the electronic shutter. Many thanks! Link to post Share on other sites More sharing options...
Advertisement Posted November 12, 2024 Posted November 12, 2024 Hi uaqpau, Take a look here Q3 continuous drive 15fps / is it mechanical shutter?. I'm sure you'll find what you were looking for!
LocalHero1953 Posted November 12, 2024 Share #2 Posted November 12, 2024 I can't answer for the Q3, but on my Q3 43 it is electronic at 15fps. I think the change is between 5fps and 7fps, but I don't have it to hand to check. I wanted to know for the same reason as you. Link to post Share on other sites More sharing options...
Smogg Posted November 12, 2024 Share #3 Posted November 12, 2024 2 minutes ago, LocalHero1953 said: I can't answer for the Q3, but on my Q3 43 it is electronic at 15fps. I think the change is between 5fps and 7fps, but I don't have it to hand to check. I wanted to know for the same reason as you. 7fps mechanical 1 Link to post Share on other sites More sharing options...
ioriardy Posted August 20 Share #4 Posted August 20 I was using 15fps today. i didn't hear the camera make a shutter sound. I knew something must be wrong, and when I got home I noticed the jelly effect was bad (indoor lighting is also at risk of banding effect). From now on I will stick to a maximum of 9fps. Link to post Share on other sites More sharing options...
LocalHero1953 Posted August 20 Share #5 Posted August 20 I have just checked my Q3 43. It uses the mechanical shutter to 9fps, but 15fps is electronic. According to the menu settings, 9fps is 12 bit and has no AFc, while 7fps is 14 bit and no AFc. 5fps is 14 bit with AFc. 1 Link to post Share on other sites More sharing options...
