setuporg Posted October 9, 2024 Share #1 Posted October 9, 2024 (edited) Advertisement (gone after registration) The focus peaking is generally useless and distracting on an M both on the LCD and in Visoflex. I always forget how to disable the damn thing, apparently per user profile?! I do not use user profiles so the whole conundrum has to be swatted away in some volatile and forgettable spasm after some firmware update or a blue moon brings it back. It is accompanied by a red-white person, as if it were some Polish or Swiss user profile. Same weirdo on SL-2. Now that I’ve extinguished the red dots on an LCD, they show up in the Visoflex 2 when attached to the M11-D. This is what I got it for, close-range focusing with the new Summicrons, 28 and 35 APO on the D. Since there’s no more menus I don’t know how to get rid of it. The FOTOS app seems to only set basic features. Any ideas? Is there some general way to only have optional focus peaking while pressing the function button that also causes magnification, which is what’s really helpful? Edited October 9, 2024 by setuporg 1 Link to post Share on other sites More sharing options...
Advertisement Posted October 9, 2024 Posted October 9, 2024 Hi setuporg, Take a look here Focus peaking in Visoflex on M11-D. I'm sure you'll find what you were looking for!
Derbyshire Man Posted October 10, 2024 Share #2 Posted October 10, 2024 (edited) Unlike the M11P/M on the M11D there seems to be no way to turn off focus assist in the menu, however it is done with the function button when the visoflex is connected, each press adds an additional level of 'assistance' until it cycles to the beginning; No aids Red focus peaking Full shooting details and histogram Grid and level Back to no aids In the same way, the back thumbwheel controls the level of magnification, none -> medium -> maximum -> none. Worth noting it only behaves like this when the mag box is showing in the bottom left, otherwise it defaults to exposure compensation. To get back from focus mag to exp comp half press the shutter, to go to mag change the focus. Quite elegant really. Edited October 10, 2024 by Derbyshire Man 2 Link to post Share on other sites More sharing options...
Loplop Posted October 10, 2024 Share #3 Posted October 10, 2024 Nice. I suspect that’s pretty instinctive, especially once you have done it a few times. Does it remember your last setting, or do you have to cycle through them every time? I suspect it remembers. The normal M11 remembers zoom level in the same scenario. 1 Link to post Share on other sites More sharing options...
hdmesa Posted October 10, 2024 Share #4 Posted October 10, 2024 8 hours ago, Derbyshire Man said: Unlike the M11P/M on the M11D there seems to be no way to turn off focus assist in the menu, however it is done with the function button when the visoflex is connected, each press adds an additional level of 'assistance' until it cycles to the beginning; No aids Red focus peaking Full shooting details and histogram Grid and level Back to no aids In the same way, the back thumbwheel controls the level of magnification, none -> medium -> maximum -> none. Worth noting it only behaves like this when the mag box is showing in the bottom left, otherwise it defaults to exposure compensation. To get back from focus mag to exp comp half press the shutter, to go to mag change the focus. Quite elegant really. So with the Visoflex 2 attached to the M11-D, the function button no longer toggles through remaining shots, battery percentage remaining, etc. in the rangefinder? Link to post Share on other sites More sharing options...
Derbyshire Man Posted October 10, 2024 Share #5 Posted October 10, 2024 4 hours ago, hdmesa said: So with the Visoflex 2 attached to the M11-D, the function button no longer toggles through remaining shots, battery percentage remaining, etc. in the rangefinder? No, display info cycle. Of course the display will show that and a load more on setting 3/4 and 4/4. 1 1 Link to post Share on other sites More sharing options...
Derbyshire Man Posted October 10, 2024 Share #6 Posted October 10, 2024 11 hours ago, Loplop said: Nice. I suspect that’s pretty instinctive, especially once you have done it a few times. Does it remember your last setting, or do you have to cycle through them every time? I suspect it remembers. The normal M11 remembers zoom level in the same scenario. It remembers! 1 Link to post Share on other sites More sharing options...
downstairs Posted October 11, 2024 Share #7 Posted October 11, 2024 Advertisement (gone after registration) The mag-box is just an obstruction since the zoom is centered. Link to post Share on other sites More sharing options...
