I pulled out my SL2 after a long hiatus and put on my APO 90mm for some portrait work.
The camera is set to manual focus, high focus peaking sensitivity and manual ISO. I have  v.5.0 firmware.
The red focus peaking is nowhere in my EVF.
I didn't see a cure in a previous thread.
Suggestions/Solutions, anyone?
Thanks in advance,
Rob
Section 5 of the SL2 Menu
Camera Settings  --- Capture Assistants ---Infio Profile 1, 2,3,4  select what you want using Setting, including having focus peeking on or off
This assigns what you se in the finder as you press the Function button (the one between Play and Menu)
To make my life easier, I attached a rubber bumper on that button (the kind you use on furniture or back of picture frames.
press the fn button several times to cycle through and peaking should appear IF its on in the focus peaking sub. menu
that is how you turn it on and off.
But some settings don't work if you have "enhanced live view" on, you should probably turn it off
Rjsphd,   I suggest you simply do a reset of the camera to original factory settings and redo your profiles and settings.  r/ Mark
PS  You might brush up by reading the manual for setting profiles and settings if you haven't used the camera in some time.
Edited by LeicaR10
